Extra cigarette lighter plug
07-27-2006, 07:10 AM | #1 |
Rep 7
I am looking for an elegant solution to mount a portable navigation system like a MIO 710 or TomTom device on the dashboard of my 320d, non iDrive of course, non Logic 7, without having a bunch of cables running all over. The dashboard has a cover plate, that might allow me to add another cigarette lighter plug as a power source.
On RealOEM.com the part is referred to as ‘COVER FOR CENTER SPEAKER, SINGLE SCOOP 51457123749’, the plug used in the centre console ‘PLUG-IN SOCKET WITH PLUG 61346947184’. Does anyone know if there are power cables behind that cover that can be tapped into for this purpose? Would it be hard to get a cable to the fuse box? |
07-27-2006, 07:27 AM | #2 | |
Deny everything
217
Rep 11,378
Drives: 2006 330i; 2015 X6, S1000RR
BMW sells a cable that will plug into the flashlight to get the entra power plug.
I need a drink |
07-27-2006, 08:03 AM | #3 |
Rep 7
I would like to have the power plug on top of the dashboard, right below the windshield, I believe the logic7 has the centre speaker there.
I will have another look, but I think there is no flashlight in the European (Belgian) version. Last edited by DirkB; 07-28-2006 at 02:59 AM.. |
01-09-2007, 03:31 PM | #4 |
Rep 43
Was there ever a solution here? Is there a way to install a power outlet at the top of the dash board, under the center speaker cover in the non Logic 7 cars? I am also interested in this for my nuvi 350. Any help or info is appreciated! If all else fails I will probably run the cable along the dash trim like another member on this forum, back to the plug in the center armrest.
01-10-2007, 07:43 PM | #5 |
Rep 29
Hi,
I've taken out the cover before and was also trying to find a power line under the center cover... unfortunately there are none... Finally I run an additional wire to the fuse box... Cheers |
01-11-2007, 07:16 AM | #7 |
78
Rep 247
just run a wire to the fuse box... will be cleaner install. btw have you got a clip for your tomtom yet? I am trying to figure out a way to mount mine (although I have iDrive in my car)...
