      04-20-2009, 09:39 PM   #1
Xaeryan
Xaeryan's Avatar
38
Drives: Sideways mostly
2010 SCCA Solo - Chart of Modifications by Class
In deciding on what SCCA Solo class to compete in (while awaiting my 135i!), I came up with a handy chart of class modifications I'd like to share with you all (which includes many common 135i modifications):
http://goo.gl/qoJBQ
This chart should not be your definitive guide, but rather a first-draft; once you decide on a class using it, read the rulebook closely (get a copy here: http://www.scca.com/downloads) to make sure no modifications you have fall into any exceptions.
I interpreted the rules as best as I could, please correct me if I am wrong on anything. Particularly if you plan on competing in Nationals, always err on the conservative side for any gray areas and assume the modification is illegal until clarified otherwise.
Comments/suggestions/corrections appreciated. If you see parts that are not listed you think should be, let me know.
Happy racing!
      04-20-2009, 09:58 PM   #2
lib
lib's Avatar
141
Drives: <This space for rent>
Thanks
      05-18-2009, 08:12 PM   #3
wolfson.tyler
wolfson.tyler's Avatar
12
Drives:
very helpful thanks a lot
      03-29-2010, 06:29 PM   #4
Xaeryan
Xaeryan's Avatar
38
Updated to 2010 specs, added more 135i specific mods, fixed some incorrect interpretations.
Any rule interpretation experts care to clear up the few I'm still unsure of?
      03-29-2010, 09:41 PM   #5
cpt97m3
AutoXer
34
Drives: 2009 135i
SM allows full metal bearings/bushings. Totally free as long as it bolts to the OE chassis pickup points.
2009 135i, Alpine White, 6MT, M-Sport, iDrive, iPod/USB, Heated Seats, Premium Sound, BMW Assist
      03-29-2010, 09:44 PM   #6
cpt97m3
AutoXer
34
Drives: 2009 135i
Also, STU does not restrict the wheel offset like in stock.
      03-30-2010, 08:20 AM   #7
Xaeryan
Xaeryan's Avatar
38
Cool, to be updated. Thanks!
Yes, I have that listed for the wheels. For the spacers, however, I couldn't find anything explicitly saying the allowable offset, so I defaulted to the stock rules.
However, I believe it would be safe to say the following: if the wheel offset is unlimited, the spacer offset should be unlimited as well.
I will change that one later on, thanks for catching it!
      03-30-2010, 12:08 PM   #8
nordique14
No_Country
53
Drives: SGM 135i 'vert
lol @ the clutch delay valve moving you from stock directly to SM. Sure would be competitive in SM with a stock 135i with only a missing clutch delay valve.
      03-30-2010, 12:38 PM   #9
RaceTime
Auto X'er
Drives: 2009 Space Gray 135i
Really cool! Nicely done!
2009 135i SGM, Premium, Sports, Nav.
Dinan Stage 2 software, Injen intake, RR Oil Catch Can, H&R Pro-coilovers and springs, H&R front sway bar, Vorshlag camber plates, Vorshlag comp studs, BMW strut brace, BMW performance pedals, G-Force harneses, BMP tow hooks, Breyton GTS-R wheels with 255-35R18 (square set up) and custom axel back exhaust with muffler delete.
      03-30-2010, 12:48 PM   #10
RaceTime
Auto X'er
Oh, I believe that an air intake is legal in BSP...if not I have been running illegally. I reviewed the rules and I believe they are OK...
      03-31-2010, 12:31 AM   #11
cpt97m3
AutoXer
34
Drives: 2009 135i
That's correct, air intake is legal in BSP.
      03-31-2010, 10:13 AM   #12
Amalfitano
15
Drives: 2009 135i STEP, Future //M2012
2009 135i  [0.00]
In comparing the Indexes, something really jumped out at me...
the 335i is F-Stock as opposed to our D-Stock 1.
If say the target is 55 RTP in open street tire, our 1's 60.6 second time is equal to a 3's 59.7. Sure the 1 is soft up front but is the geometry that much different for the class jump? In either case both go the STU, BSP route, and in the end you're basically going against your own class, but i'll definitely be open street tire stock for this year at the least.
Also sort of strange that the 128 and 135 stay the same class...
      03-31-2010, 06:49 PM   #13
Xaeryan
Xaeryan's Avatar
38
I'm confident nobody would care if you did a CDV until we are talking about Nationals competition level, but yeah nothing explicitly states you can modify the clutch system other than discs/flywheels in BSP.
Yes, since it is legal in street touring, you are correct that it would be legal in street prepared. To fix...
      08-31-2010, 11:54 PM   #14
Xaeryan
Xaeryan's Avatar
38
Updated and bumped for those who might need it.
As discovered in TIS, alignment pin removal is listed in factory manual, so go for it all you D-Stockers!
Here's the TIS page with it listed: http://www.1addicts.com/forums/showp...7&postcount=16
1addicts
