      04-07-2009, 03:22 AM   #1
jeremydgreat
jeremydgreat's Avatar
76
Drives: 2009 135i
Magnetic numbers for track days/autocross?
Does anyone know if magnetic track numbers will work on the sides of a 135i? I'm not sure what the doors (or rear side panels) are actually made of. Has anyone had any experience with this?
135i // M-Sports Package // RR Oil Catch Can // Black Kidneys // iCarbon Hood // Alum Pedals // KW v2 Coilovers // Vorshlag Camber Plates // Hotchkis Sway Bar // Wheel Studs. Best mod ever? Tires. 255's in front, 275's in back.
      04-07-2009, 04:20 AM   #2
white911
white911's Avatar
16
Drives: 135I - white/coral red - sport
If you have 'permanent numbers', go to a sign shop and have them made. You can have the numbers made the way you want them. Also you should have them made on a flat sheet which could be chosen to match the color of your car or contrast with it. Don't get just the number there is too much frontal area compared to the gripping area and the numbers won't stay on your car at any kind of speed. On the track for added security tape the leading edge of the number panel with a small amount of racers tape. So it's a good idea to get your number panel in the same color as a big roll of racer's tape.
Alan
08 135I (AW/Coral Red - delivered 3/15/08 --
13 Audi S4, 83 SC (trackster), 90 C2 (Sally's Carrera), 04 Avalanche Blingmobile
      04-07-2009, 09:54 AM   #3
jeremydgreat
76
Drives: 2009 135i
Ah, good tip on the tape. By "permanent numbers" though, do you mean that the numbers themselves never change? Or did you mean permanent as in "they aren't removable"?
I'm trying to figure out if magnetic numbers will even "stick" to the doors of a 135. I'm thinking of just ordering a magnetic oval from here.
      04-07-2009, 10:10 AM   #4
lib
lib's Avatar
141
Drives: <This space for rent>
Magnets will stick to all of the exterior body panels.
      04-07-2009, 11:11 AM   #5
white911
white911's Avatar
16
I meant permanent as you are assigned a number for the season e.g. 46 - If you show up for an out-of-region event where someone has stolen your number, you may change it with painters tape - leading 1 or trailing 1 as in 146 or 461
Alan
      04-07-2009, 08:27 PM   #6
jeremydgreat
76
Drives: 2009 135i
Great advice everyone.
Any suggestions on size? I think I'm just going to order some magnetic numbers from here. What size should I get? Also, I notice that I can order a few letters for "class" denotations. The suggested letters are "CSP". (see here) Any suggestions there?
(I'm trying to order these before the car actually gets here, and then attend a track day not long after. )
      04-07-2009, 09:52 PM   #7
lib
lib's Avatar
141
^ $110-169 seems VERY steep for simple magnetic numbers. Especially if it's just a set of standalone 0-9 + class letters (most of wihch you won't use). For that price you should be able to find something much nicer.
If you want simple stand-alone numbers like that you're much better off buying some of the material and cutting them out yourself. It's a hell of a lot cheaper and you have full control over the result. You'll also have some extra material if you ever loose a number or change your class. All you need are a pair of 2 (at most 3) numbers and class letters. I personally just have a 1, 5, 6 and DS for each side which provides more than enough possible combinations. As a bonus, mine were free since a coworker had extra magnetic material laying around.
If you want something fancier, someone else may be able to point you to a better source.
      04-08-2009, 12:39 AM   #8
one-35
one-35's Avatar
20
Drives: BMW e92 M3
I use the 12" x 18" car door magnet from vistaprint.com. Works great on the track (even driving there & back); simple; very strong/never falls off. Here's a link for saving 50% off...
http://www.vistaprint.com/vp/busines...agnet&ad=broad
IIRC, a set of 2 costs approx. $30 shipped! White background is best for ease of visibility and photos.
      04-08-2009, 01:22 AM   #9
jeremydgreat
76
Drives: 2009 135i
ooh that's not a bad idea. Is the magnet thin enough to cut the numbers out?
      04-08-2009, 09:48 AM   #10
white911
white911's Avatar
16
Don't do this, the magnets cut to the shape of the number do not provide enough surface area compared to the frontal area. The sides of tracks are littered with these numbers. Any speed over 60 and the numbers are at risk. A rectangle background magnetic panel provides the least frontal area compared to the surface area. Numbers and circles do look fairly interesting whirling through the air.
To make number plates yourself get the larger door magnet which provides less frontal area then almost any number. Use the door magnet and vinyl coat it or paint it and attach vinyl numbers to it. If you have a white car or you have a different color car, attach the vinyl numbers directly to the magnetic panel without painting it to match your car before hand. You can even lay one color vinyl number over another to achieve a shadowed look.
Alan
      04-08-2009, 01:40 PM   #11
R32
Drives:
really, i think you should forget about magnet numbers except for autocross. sure, you can tape them down, but then you could have just used tape to make the number anyway, which is ghetto.
i tried with some success some reusable vinyl numbers. they stick well at first, but eventually you get grit/dust on the sticky side, and eventually you have to replace them.
lately, i have been using temporary spray paint that you can get at autozone. you can have flexibility as to the number and size. you have to cut out a stencil, which takes all of 3 minutes, and spray. this is also pretty ghetto, but tidy enough, and cleans up easily.
http://www.duplicolor.com/products/carart.html
      04-08-2009, 04:49 PM   #12
white911
white911's Avatar
16
Everyone has an opinion. The tape does not have to be done in a way that appears to be ghetto. Particularly if your number panel is the same color as your racer's tape. Perhaps I will take some pictures this weekend at Summit Point to use as examples.
Alan
      04-12-2009, 11:21 AM   #13
Dezmo
LEFT LANE FOR PASSING ONLY
Dezmo's Avatar
Drives: 2012 135i
I'll get a better photo of mine up soon, but this works perfectly. I drew up a word document and emailed it to a local franchise type of print shop (Fast Signs I think) and they had it done in 4 days for $60 (2 magnets). I made this one similar to what the BMW Motorsports uses for their race cars. BMW Motorsports at the top, number in the middle, & BMW 128i Coupe on the bottom. Black line arount the edge. They rounded the corners so it would not peel away. If you are doing SCCA & need to indicate class have it printed or just add some blank spce to the right of your number and use the vinyl stickers. The next one I do will have some colors and some blank space to the left of the number for sponsor type stickers & possibly my last name.
      04-13-2009, 09:14 AM   #14
ssabripo
HALA MADRID!
ssabripo's Avatar
939
Drives: camels & donkeys
try this...great price and quality too:
http://www.izoomgraphics.com/
F87 M2 Competition, Sunset Orange, Exc, DCT.
**SOLD** F80 M3 Mineral Grey/Sakir Orange, Exc, DCT... ED 6/2015
**SOLD**E90 M3, Interlagos Blue / M individual two-tone, ZCP, ZP2, ZCV, DCT, ED.
      04-13-2009, 11:21 AM   #15
jeremydgreat
76
Drives: 2009 135i
^ Thanks for the link!
Thanks for posting the image Dezmo. Very helpful!
      04-14-2009, 09:58 PM   #16
BimmerMeUp
12
Drives: 2008 135i
Good options here as well, happy with mine:
http://www.soloperformance.com/
2008 135i Sparkling Graphite Metallic - 6Sp - Black Boston Leather - Gray Poplar trim - Sport Package
Premium Package - Comfort Access - iPod/USB - HD FM - Premium Hi-Fi - Heated Seats
5/27 Euro Delivery Welt - 6/5 Drop off AMS - Re-Delivery 8/8 - SOLD 8/2015
      04-16-2009, 11:18 AM   #17
aarong_m3
20
Drives: 2006 BMW M5 / 1974 BMW 2002
I'm having mine made. My bro-n-law did this one for me. Lmk which one looks good. Thx. Sorry for being so big..as ineed it to uplaod to a website.
2006 BMW M5 7spd SMG/SIlverstone : 2008 BMW 135i SGM/JB2/BMS(SOLD 1/2010) : 1974 BMW 2oo2(5spd w/ 3.91LSD) : 2002 BMW M3(AW/6spd) Sold 8/07 : 2002 BMW 325i(SGM) Sold 12/07 : 1993 BMW 325i Sold 8/04
      04-25-2009, 02:05 PM   #18
jeremydgreat
76
Drives: 2009 135i
Which size do you think would work well with a 3-number (no class letters) oval shape? My 135i is still on the boat or I'd just go out an measure.
Click here for the size chart (it's huge or else I'd just put it in this post)
Initially I'm thinking 20" wide and 11" tall is pretty darn big on a 1 series.
      04-25-2009, 03:00 PM   #19
BimmerMeUp
12
Drives: 2008 135i
10" numbers with 5" letters on my 135i
      04-26-2009, 04:18 AM   #20
jeremydgreat
76
Drives: 2009 135i
Thanks BimmerMeUp! That was very helpful. Did you choose removable vinyl, magnetic, of permanent vinyl for those numbers? They look great.
      04-26-2009, 11:17 AM   #21
BimmerMeUp
12
Drives: 2008 135i
Those are magnetic. That's pretty much what everyone uses at our autox events. Vinyl can look great, but is more of a pain to put on (have to work the bubbles out with some solution) and don't last as well (get dirty). The magnetic material from Solotime works great, we only occasionally have to retrieve someones numbers from the course, and usually that's because they have gotten curly and have edges sticking out into the wind.
I store mine on a box I built with a top made from an old whiteboard; the older whiteboards were made from sheet metal and magnets stick. I've seen folks with a loose leaf binder of sheets of metal to store numbers - you want to try to keep them clean and flat. Sometimes, if it is cold, I'll let them sit on top of the engine for a few minutes to warm up, then they bend to body contours better than if cold and stiff.
Good luck!
      04-26-2009, 12:05 PM   #22
lib
lib's Avatar
141
That's a nice little trick!
1addicts
