04-05-2009, 03:48 PM | #1 |
27
Rep 184
How do I connect both HD indoor antenna and Satellite to TV?
I bought a HDTV for my parents and I was planning on using an indoor antenna to pickup the local over the air HD channels. My parents currently have a Satellite connection in their room, which connects to the TV using a coax cable (from wall to TV). The indoor antenna also uses a coax cable to connect to the TV, however, The TV only has 1 coax connector! What do I need to do so I can use both at the same time? Some kind of 2-in-1 coax connector??? Would there be interference if I combine both signals?
04-05-2009, 04:30 PM | #2 |
エアーマンが倒せない
271
Rep 2,041
I believe we have the same setup. The wired receiver is in the living room (HDMI cable connects to the TV in that room) and we have another TV in the guest room that doesn't receive the HD. There doesn't appear to be any way to connect HD to the guest room without another receiver.
04-05-2009, 05:36 PM | #3 |
240
Rep 1,247
Drives: E60 M5, E71 X6M, E46 M3
Garage List 2006 BMW E46 M3 'vert [0.00]
2008 BMW M5 [0.00] 2011 BMW E92 [0.00] 2012 BMW X6M [0.00] 2003 E46 M3 [0.00] |
which sat (direct or dish)....if dish...you can plug the ant into the sat box...then you can set-up the box to pull your locals (depending on the model of the box)....if direct, you need to diplex
spend some time at http://www.satelliteguys.us/index.php
Current: 2006 E46 M3 'vert 6-sp 2008 E60 M5, 2011 E92 328 6-sp, 2011 E70 N55, 2012 E71 X6M
