19's and best % combination 225 fronts?
04-05-2009, 08:29 AM | #1 |
Rep 52
Unless I am making a mistake isn't the best % combination for xi with 19's a 225-35R 19 on the front with 265-30R 19 closer (better) than using a 235 on the front? Seems that way on Tire Rack specs. Am I wrong? Was going to get 235 for front but now I am questioning that?
04-05-2009, 10:13 AM | #2 |
Gearing
86
Rep 3,965
The OEM staggered setup on 18s is 255/35/18 and 225/40/18 and 19s are 255/30/19 and 225/35/19. That is reference that can be put thru any tire size calculator (The Tire Rack forum here has one).
I have 265/30/19 and 235/35/19 (10.5" and 8.5" M1 replicas) - Tons of understeer. Looks nice though. The key is to maintain the run diameters as close to OEM as possible and to keep any % difference between front and rear run ratios as close to zero percent as possible. This is a good tire size calculator http://www.1010tires.com/tiresizecalculator.asp
If at first you don't succeed ...
04-05-2009, 06:25 PM | #3 |
325
Rep 5,370
i have 225/35/19 up front and 255/30/19 which is the oem tire size. you're best bet is to stay as close to that as possible to net you the least % variance.
04-06-2009, 05:46 AM | #5 |
325
Rep 5,370
