Spacer experience?
06-25-2006, 12:18 AM | #1 |
119
Rep 2,909
Spacer experience?
Ok, I've been reading a lot about certain spacers cracking and so on. What's everyones experience been with spacers like Rogue Engineering, H&R, etc????
06-25-2006, 12:21 AM | #2 | |
Not Stock
160
Rep 2,774
06-25-2006, 01:21 PM | #4 |
20
Rep 395
Drives: 323i Msport; DC2R (track car)
I have H&R 15mm on my Z4
never have problem
06-25-2006, 02:31 PM | #5 | |
Not Stock
160
Rep 2,774
06-25-2006, 03:07 PM | #6 |
155
Rep 6,158
that's why you put anti seize on the hub when you install them
sounds like you have a quality of installation problem rather than a quality of product problem I ran spacers on my E30 for over 100,000 miles over 7 years or so with no issues, and I autocrossed a lot back then...... not sure what brand they were, tirerack sent them with my wheels I'd bought from them |
06-25-2006, 04:41 PM | #7 | |
Not Stock
160
Rep 2,774
06-25-2006, 05:25 PM | #8 |
it can never be too clean...
163
Rep 1,100
i have h&r spacers on one of my others cars... i had a time getting them off but no cracking once removed... no anti-seize used either.
'14 328xi wagon / m sport / white / red leather kw v1 coilover kit / 19" staggered 351 M double spoke wheels / upper strut bar / sport line grille & exhaust tips / 50% tint / painted reflectors / debadged / complete clear bra |
06-25-2006, 06:12 PM | #10 |
196
Rep 4,095
Drives: F30 328i
I just got the H&R 10mmspacers for my rear a couple weeks ago so well so if they last!
Thanks for the heads up diesel!
06-27-2006, 11:40 AM | #12 |
Black Sapphire 330i
32
Rep 362
I'm running Rogue 12mm on the rears, only because they came with the longer bolts. The Rogue is also purposely machined with an diagnal (1mm) outer lip to aid in the removal process. I think they're 6061 aircraft aluminum for light weight and strength.
06-27-2006, 12:11 PM | #13 | |
47
Rep 355
I believe you cannot put H&R 10mm spacer on the rear of E90. The original center hub is too long and will hit and crack the center ring of the spacer. This will happen when you tighten the wheel. You will not notice it until you take the spacers off. However, this won't happen if you use the 10mm spacers at front since the front center hub is shorter than the rear. I knew this because I use H&R TRAK+ spacers 12mm Front & 10mm Rear. My shop had the original rear center hub grinded for 2mm to keep it out of contact with the spacer ring. So all good now. Actually, before the hub's grinded, you can feel it that the H&R 10mm spacers do not sit very well when you put it on the rear. I'm not sure why H&R didn't put a note or warning on the manual. Maybe only the newer BMW model have longer hub?
06-27-2006, 01:08 PM | #14 | |
Not Stock
160
Rep 2,774
Interesting, this is also why it was so hard to remove when I changed wheels. That is very informative info. No one install H&R spacers without gringing the hub centric ring or else they will crack and be nearly impossible to remove . |
06-27-2006, 01:17 PM | #16 | |
196
Rep 4,095
Drives: F30 328i
06-27-2006, 01:19 PM | #17 | |
47
Rep 355
I think H&R is a superior product. I've been using this spacer since my previous Bimmer. More than 5 years old that is. No problem at all.
06-27-2006, 01:34 PM | #18 | |
Not Stock
160
Rep 2,774
06-27-2006, 01:41 PM | #19 |
//Mdicted
347
Rep 9,988
Drives: a Cop Magnet
Garage List 2009 e92 M3 DCT CF ... [10.00]
2015 S-Works Roubaix [0.00] 2013 Trek Madone 5.9 [9.50] 2012 Scott - CR1-Pro [10.00] 2008 e92 M3 6MT (Up ... [10.00] 2002 e46 M3 Cabriol ... [7.00] 2006 e90-325i (DD) [7.00] 2002 e39 M5 (retired) [9.50] |
I used H&R 15mm on my e90s rears, looks good !
before I put it in, I put moly grease between the plates and axle hub prevents any corrosion and seizing problems in the future. I believe greasing is important, due to the fact that its dissimilar metals, any introduction of moisture between then will act as electrolyte passing +/- charged cell and presto! exfoliation corrosion! I went with H&R because its a German product, in my hopes they know better the issues of BMW performance, Unlike, the Americans which just farm outs its jobs overseas. I would not be surprised if the same people that make H&R stuff are the ones the makes it for the other competing US companies. HA! Im keeping an eye on the rear tires inner shoulder/side walls for any earlier wearing than the outside thread, also did note immediately after the spacers were installed that a slight play in the steering wheel was observed. Is it just me
06-27-2006, 02:02 PM | #20 | |
47
Rep 355
I hope your spacers have a revised design to accomodate longer center hub.
06-27-2006, 06:33 PM | #21 |
2148
Rep 10,176
Running 5mm H&R in front, 12mm Rogue in back. No issues with either. I change my wheels a few times a month tough, so no chance of them seizing.
06-27-2006, 10:54 PM | #22 | |
47
Rep 355
