BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > All-Wheel-Drive (Xi / xDrive) Talk > Driving this weekend, hit some ice - not front wheel is crooked
      02-09-2009, 10:12 AM   #1
mds82
mds82's Avatar
364
Drives: 2006 325xi
Hey!
So i was driving this weekend to my g/f's place and went to pass someone, and well didnt see that the road was not plowed well, and ended up hitting a chunk of ice or snow in the road. The car bouced up in the air ( sounded bad) and then noticed that the steering wheel was all crooked.
Anyways, got the car re-aligned becase it was all out of whack, and not the front drivers side has WAY TOO MUCH negative camber, like 5 degrees. the tire looks like its on a Huge angle.
Took the wheel off and didnt see any major problems, the lower control arms look fine, so i'm not sure what is wrong?
Could i have bent the Strut / shock ???
Any ideas
      02-09-2009, 11:05 AM   #2
djordje
Drives: 335d Msport AW
2006 320d  [0.00]
check wishbone and strut. if changing them wouldnt help, check wheel carrier and wheel hub.
      02-09-2009, 02:19 PM   #3
BavarianBullet
BavarianBullet's Avatar
18
Drives: 2014 Audi S5
Originally Posted by mds82 View Post
Hey!
Any ideas
Ouch. This is a pretty serious impact. I'd suggest calling it in to insurance as I could see the parts and labor totalling up pretty high, like over $2000.
If you want to go it alone and try and fix it yourself you may wind up swapping a number of parts. It could take months to fix doing it piecemeal. You may save a bit but to me, unless you get lucky, it really doesn't seem worth it.
Good luck.
BB
2014 Audi S5 DSG
2011 335xi Sedan (retired)
2008 335xi Sedan (retired)
      02-09-2009, 02:47 PM   #4
mds82
mds82's Avatar
364
Drives: 2006 325xi
Good luck.
BB
I can do everything myself for parts install, thats not the problem. Right now i just dont know what exactly is wrong though.
All of the control arms look fine too
      02-09-2009, 04:13 PM   #5
jzchen
12
Drives: '08 335xi E90
When I hit something on the road, it bent my strut, (as well as my rim), so I'm betting that's the culprit. Why don't you try changing that first?
      02-10-2009, 11:55 AM   #6
mds82
mds82's Avatar
364
Drives: 2006 325xi
off to the dealership on friday - let them figure out whats wrong....
Sucks being out of warranty
      02-15-2009, 10:03 AM   #7
devilzrule
devilzrule's Avatar
Drives: 07 328 xi
even if you had warranty, the dealer would not pay for the damages. its not maitenence.
      02-15-2009, 10:41 AM   #8
BavarianBullet
18
My concern is that you'd wind up just wasting a lot of time and spend just as much doing it yourself or have to call it into the insurance anyways because the parts bill will be high enough.
Good luck with your repairs and let us know what the dealer says. I'm interested in hearing what is wrong with it.
2014 Audi S5 DSG
      02-15-2009, 11:53 AM   #9
Nikolas
313
Drives: 996 TT
Why are you worried about the cost - you have insurance I assume?
      02-16-2009, 08:16 AM   #10
mds82
mds82's Avatar
364
Drives: 2006 325xi
Well - dealership was a bunch of BS.... Quoted me $3100 for new struts, carrier, tie rods, and other stuff.
Took the car apart and Well - i Bent the Strut - BAD.... That is all that is wrong though. So time to buy 2 new struts and then car is as good a new.
      02-16-2009, 10:54 PM   #11
nomile
10
Drives: 328xi; 318ti
Are you judging that it's 'just the strut' by visual inspection, or did you measure the parts out? If you jacked your strut, you probably did damage to the rest as well, and just b/c you can't see the damage doesn't mean that things aren't bent... If the dealer ahs good reason to want to replace these parts, I'd do it.
      02-17-2009, 01:22 AM   #12
jzchen
12
On some cars you only need to replace one. On my '92 190E they just replaced the one that got bent. You put on the strut(s), you get the car aligned, if it falls within specs, you're fine.
