WORK VS-XX wheels finally arrived.
06-22-2006, 02:40 AM | #1 |
576
Rep 6,750
3-PIECE WORK VS-XX from DTMAutohaus
F 19 x 8.5 +28 with 235/35 ZR19 Toyo tires R 19 x 10 +26 with 265/30 ZR19 " Last edited by ksfrogman; 06-23-2006 at 11:05 AM.. |
06-22-2006, 03:09 AM | #5 |
47
Rep 355
That's a great comparison you've made.
I should've done the same with mine before they got dirty and nasty. BTW, I think the tires are not Toyo T1R, are they? |
06-22-2006, 03:15 AM | #7 |
Got Seoul?
116
Rep 2,862
Drives: 2012 535i MSport
Nice! Can barely tell the difference in height. What is with the center hub? How do you like the Toyo's?
Can you say Alooooha?
[SIGPIC][/SIGPIC] |
06-22-2006, 03:18 AM | #8 | ||
576
Rep 6,750
06-22-2006, 03:23 AM | #9 |
117
Rep 2,232
Drives: 2016 M3
Nice setup, did you get weight comparison between the stock
2016 M3
2016 Audi Q5 3.0T |
06-22-2006, 03:26 AM | #10 | ||
576
Rep 6,750
Don't look too closely, but not realizing the tires were directional, I mounted the left tires on the right and vice versa front and rear. Can you believe it? What's the probability of that happening? I'll tell you. 1/2 * 1/2 = 1/4 = 25% probability, and I did it. Damnit. Oh well, I just switched them around the correct way. Quote:
My only disappointment is the weight of the wheels without the RFTs. I thought these aftermarket ones would be much lighter despite the larger diameter and width. Only a marginal improvement was seen. However, these are the figures: STOCK LF = 55.2 lbs vs 52.8 lbs WORK LF STOCK RF = 56.6 lbs vs 51.8 lbs WORK RF STOCK LR = 58.2 lbs vs 56.6 lbs WORK LR STOCK RR = 58.4 lbs vs 56.6 lbs WORK RR Apparently these wheels are cast aluminum, not forged. The discrepancy in weights might be due to my cheap digital scale. |
06-22-2006, 03:30 AM | #11 |
576
Rep 6,750
One more interesting digression...
I jacked up the rear of my car and the front wheel came off the ground. Man this car is stiff. I'm not sure if all E90s are this way or if the aftermarket sway bars + strut bar make it like this. |
06-22-2006, 03:39 AM | #12 | |
47
Rep 355
Frogman, I think you put the wheels in the opposite direction. I hope I'm wrong. But please check the rotation sign on the tires. |
06-22-2006, 03:42 AM | #13 | |
576
Rep 6,750
See post #10 above. I corrected the problem. |
06-22-2006, 03:51 AM | #14 |
23
Rep 498
Drives: E90 325i
Now, your car looks perfect! ASTIG!
06-22-2006, 04:56 AM | #15 |
20
Rep 395
Drives: 323i Msport; DC2R (track car)
Looks good.
Any rubbing problems?
06-22-2006, 05:13 AM | #16 |
47
Rep 355
[quote=ksfrogman]Maybe not. I thought they were supposed to be so I looked at them carefully. They say Toyo, but Proxes4 (whatever that means). Treadwear is 300. What do I have?
quote] Yeah, I believe yours are Proxes 4. I was wondering at first, how come your treads are different than mine (T1R). Still great tires though. At least Toyo prices are much friendlier than Continentals or the likes. :rocks: |
06-22-2006, 10:00 AM | #17 | ||
576
Rep 6,750
With the rear offsets at +26, the wheels are sticking out a little bit but the 265 tires have a chamfered edge that are directly above and parallel to the extra inner fender lip edge. Two or three times as I hit a big bump in the road, the right rear rubbed slightly (I have H&R Sports). I hope I corrected it by pushing in the closest point on the fender. I'll see today. Quote:
06-22-2006, 10:04 AM | #19 |
Moderator
318
Rep 17,767
Drives: F36 428i,E90 328i, E85 Z4 3.0i
Very very nice
Long and you sure are leading the way in SG hotness As mentioned, I would work on the center caps, the current one detracts too much from the looks. Are you thinking about the lip (either CF or painted or Studie) to the front M bumper? edit: I forgot to mention Diesel's car in the SG hotness comment
Official DC Metro Registry - Current, New & Prospective Area Members Roll Call! Last edited by KL2DC; 06-22-2006 at 10:33 AM.. |
06-22-2006, 10:09 AM | #20 |
Administrator
40871
Rep 21,240
HOTTT!! Congrats on finally getting the wheels Michael, seemed like an eternity.
Check on the Latest BMW News
Become a fan of Bimmerpost Facebook Follow us on Bimmerpost Twitter Subscribe to Bimmerpost Youtube Channel |
06-22-2006, 10:17 AM | #21 |
Moderator
497
Rep 27,441
very nice michael!! great choice in wheels!!
06-22-2006, 10:18 AM | #22 | |
576
Rep 6,750
As for the M front, I don't much care for the M CF splitters. They don't blend in as well as the stock bumper splitters do. Then again, I've not seen anyone with painted CF ones for the M. I have actually gotten use to the look--in two dimensions, the mind's eye sees the extra plastic piece "filling in the void." See photo. It's also a matter of function over form, as I don't like driving like grandpa to avoid scrapes. |
