Technical problems
06-19-2006, 07:45 PM | #2 |
418
Rep 12,276
Escalate the problems to BMWUSA. Insist that the SA escalate and give you a copy of whatever they file. Honestly, it sounds like they are just being lazy - especially with the steering wheel. If they give you trouble, contact BMWUSA yourself. Don't expect much from them either - but at least it will be documented. Get the names of people you speak with.
You might want to be tolerant for a bit on the engine idle... let her get some miles on it and see if it smooths out - but still document the complaint. My $.02
I think it is bad luck to be superstitious |
06-19-2006, 07:47 PM | #3 |
Brett Dearman - Retired Über-geek
Rep 3
Issue #1 sounds pretty mysterious. I mean, it's certainly true that an extreme road crown (or adverse cambre as they say in the U.K.) can cause your steering wheel to seem off center, but it shouldn't be the same on every road you drive on. How does it behave in say a perfectly flat parking lot? Does it pull to right or to the left? A solid impact with a significant curb and wreck havoc on your alignment. Is it possible your car smacked something on its way to your dealer's parking lot?
As far as Issue #2 is concerned, there may be a easy explaination for that. I've actually experienced the same condition on other cars. What happens is when the weather is hot (which is about 10 months out of the year here in Houston, Texas), the A/C will engage and disengage periodically in order to keep the refrigerant in the system at the right pressure. That alone can cause a "shudder" in the engine compartment. What I've experienced is when the A/C is engaged, merely putting the car in Drive can nearly kill the engine (assuming yours has an automatic tranny). Granted, this scenario is usually associated with poorly engineered and/or poorly maintained autos, and I've never experienced it with my E90. This is the first BMW I've ever owned with A/C, so I can't say it's a "common anomaly" among BMW's. BTW: I have a manual transmission which may help eliminate any of these symptoms, but there's no doubt the A/C is working hard all the time so if I had the same problem, I'd know it. My two cents worth... bd |
06-19-2006, 07:55 PM | #4 |
***** noob
1370
Rep 10,479
Drives: 325xi>M235i>428GCx Mspor
Prblm #2...happens to me sometimes
I think is the Gas here...just a thought Did you inspect the car during re-delivery from ED? (check all tires, damages..etc) Which Dealer? I'm in the boston area too
2006 325xi (Sold)
2014 M235I (Current) 2015 428xi Gran Coupe (STB) Last edited by ska///235i; 06-19-2006 at 08:14 PM.. |
06-19-2006, 11:30 PM | #5 | |
101
Rep 3,566
Drives: F30 M-Sport 328i Estoril Blue
328i M-Sport, Estoril Blue, Carbon XP 35 Tint, front heated seats, black Dakota, Sports Suspension, Anthracite Headliner, HUD, Pro Nav, Sunroof, hk 600w, Bi-Xenon, 19" 403M wheels, Reversing Camera, DAB+, Xenon, BT Ext Connect, MST turbo intake pipe, MST Cold Air Intake, JB4 on Map 2 with Catless DP produces awesome performance in Sport.
