01-21-2009, 10:07 PM | #1 |
223
Rep 1,565
Insane Berk 135i track driving video inside!
We pieced together this really cool video of the Berk Technology 135i at the SuperLap Battle World Finals. We ran a 2:03.996 on a stock bodied, street tire car, and a "few" bolt ons. This is a good example of what you can do with your 135i street car, some hard earned coin, a bit of technical knowledge, and an addiction to track driving.
Some more info on the build can be found here: http://www.1addicts.com/forums/showthread.php?t=11907 - the 3 week build. http://www.1addicts.com/forums/showthread.php?t=19366 - the end result. Enjoy! |
01-22-2009, 01:52 AM | #3 |
295
Rep 1,201
Awesome video! So is the car pretty much built up and 100% ready? Or are there a few other parts awaiting to come out?
01-22-2009, 05:19 AM | #4 |
Scum in the sun
30
Rep 938
Drives: 135i Coupe TiAg
Sweet driving man. Especially given the fact the guy in front couldn't keep it on the track! Nice.
One should love animals. They are so tasty. |
01-22-2009, 12:53 PM | #7 |
44
Rep 647
I would love to drive there too, and the sad part is that track is only about an hour and a half drive from my house...problem is my girlfriend wont stop planning sh!t on our weekends lol....Great job Berk!!!
01-23-2009, 03:16 AM | #9 | |
My ride: bimmergirl84
22
Rep 302
Usually this results in an upshift point that's a few hundred rpm past the point of peak hp. On our 135i's, that point is around 6000rpm because our peak power is around 5700rpm. So, even though redline is at 7000, I shift around 6000 to maximize the amound of horsepower that gets "used". Thanks everyone for the kind words. I would like to say a big thank-you to Berk for letting me drive the car! Berk Technology did a fantastic job preparing this car. They spent their limited budget in all the right areas to make the car fast, set it up well, and it drove like a dream. I really enjoy driving this car, because they have taken the time to figure out what the car needs to go fast and built it right. You can't just throw aftermarket parts on a car and expect it to go fast; everything has to be tuned & tested to maximize each part, and they did just that. The car is an absolute blast :roundel: |
01-23-2009, 11:11 AM | #10 | |
Rep 222
01-23-2009, 12:47 PM | #11 |
85
Rep 1,609
Nice video. How is your time compare to others? How much did the H&R F/R sway bars improve the handling? I am thinking about just do the KW2 coil over but not the sways and wonder how much that I will miss. Thanks.
7/08 135 Coupe, Crimson Red, 6 SP, Sport, Taupe Lette/Aluminum. Performance Mods: JB4 on Map 5, BMS DP Fix V3, Injen polished intake, AR Catless DP, Maddad resonated mid-pipes, aFe exhaust polished tips, ST Suspension Coil Over and Hotchkis front sway bar. Others: BMS OCC, BT Scanner, Mud Flap. Next Mods: AA Front Strut Brace.
01-23-2009, 02:37 PM | #12 |
13
Rep 356
Nice vid - just a general observation but you seem to be having to catch the oversteer quite a few times...
ps: that track looks really fun, is it in the desert somewhere? |
01-23-2009, 08:29 PM | #13 |
Rep 222
Wow. So that is what a fully tuned 135 can do... Awesome.
Here are top time attack times for this track for comparison: http://www.timeattackforums.com/foru...k-records.html 1er does very nice... Makes me proud :biggrin:
AW/BL'ette/Sport/Cold/CA/IpodUSB
[SIGPIC][/SIGPIC] |
01-25-2009, 10:41 PM | #14 | ||||
22
Rep 302
The H&R front bar definitely helps, as it's a little stiffer than the stock one. The H&R rear bar I think may be too stiff. I want to try putting the stock rear bar back on to find out. As for matching them with KW's V-series, I think you're fine forgoing the sways and sticking to just coilovers + camber plates. If you find that to give too much oversteer (which I doubt you will unless you go to a non-staggered tire setup), then add the H&R front bar and you should be set! Like I said, it's only a little stiffer than stock, so I think you're fine keeping the stock bars. Quote:
The track is Buttonwillow Raceway. It's a very popular Indycar test track. It's about 150mi north of Los Angeles. Quote:
But, Berk's goal was to build a nice street car......that could embarass Porsches on the track Thanks for the nice words everyone |
01-28-2009, 06:03 PM | #15 | |
20
Rep 354
I think there is some problem because those links send me to other thread regards
2009 AW 135i
CP-E CATLESS DPS, AFE EXHAUST , OIL COOLER KIT,FORGE DVV,,BMW PERFORMANCE SIDE SKIRTS AND BMW P . PEDALS, BMW PERFORMANCE SPOILER , BMW PERFOMANCE KIDNEY GRILLS, CODE 3 IC, DIREZZA Z1 STAR SPEC |
01-28-2009, 11:21 PM | #16 |
I'm not as dumb as you look.
Rep 132
hey what kind of in car setup are you guys using. i've been trying to get a good mount/ camera setup going and the picure on that is pretty solid quality.
Is this thing on?
01-30-2009, 12:59 PM | #17 | |
223
Rep 1,565
http://www.bhphotovideo.com/c/produc...all_Joint.html |
