Anyone Suffer From Squeaky Clutch Pedal?
06-12-2006, 06:19 PM | #1 |
BMerDRMer 2006 330 Xi Man ZPP ZSP CW NAV CA TiAg BlkLthr Burl 18in 162's
Rep 214
1st minor (but aggravating) problem appeared on my 330Xi as the weather fianlly warmed up ......... in temps above 65f my clutch squeeks consistently on depression and release ...... tried a little WD40 to no avail ....... sounds like a rub on a rubber boot above the underdash hood ........ when temp drops below 60f, goes away .......... anyone else run into this ........ I am sure BMW can resolve this, but as its the only problem I've had, I have yet to take it in.
BMerDRMer 2006 330 Xi Man ZPP ZSP CW NAV CA TiAG Blk Lthr Burl 18x162's
06-12-2006, 08:18 PM | #3 |
52
Rep 996
Picked up my e90 is Oct (8 months ago) and it's squek-less.
2006 330i Monaco Blue | Grey | Walnut ...Manual | Sports | Premium | Cold | Nav | Comfort Access | PDC | Sirius | Sunshade ...M-Tec Steering Wheel | M-Tec Shifter | TLC ...Performance Center Delivery | Oct 14, 2005 |
06-12-2006, 08:23 PM | #4 |
Bimmer Manual all the way
66
Rep 1,811
my current 9 month old e90 does not have a squeaky clutch pedal but my 4yr old manual g9 corolla does suffer from a squeaky clutch. any permanent solutions for this problem for older cars apart from greasing and oiling the joints?
06-13-2006, 01:26 AM | #5 |
375
Rep 2,348
Mine had that sound too and i posted the article like two months ago and someone told me it's not a big problem as some new cars have that. Mine now doesn't have that noise and it's as smooth as silk.
06-13-2006, 02:02 AM | #6 | |
51
Rep 921
older BMW (E36). I've learned to live with it after 13 years whenever I drive the car with high temperatures outside. |
06-13-2006, 06:07 AM | #8 |
20
Rep 276
Drives: E90 330i SE
I used a clear sillicone spray to cure any rattles or squeaks on my old E36, which suffered the clutch issue.
The spray also cured my E90 window and door rattle, by simply spraying the rubbers. |
06-13-2006, 06:36 AM | #9 |
Powderhound
Rep 32
No squeak here, 6,000 mls...
Powderhound
'06 325xi - 6spd man - Prem. Pkg - Sports Pkg - Cld Weather - iDrive - Xenon - SAT R. - graphite / poplar / black |
06-13-2006, 11:36 AM | #10 | |
Rep 6
When I got my E90, the clutch would squeak at the same point on depress and release. It took the dealer three tries in order to finally fix the problem. It turned out there was something loose (sorry, can't remember what) in the transmission. The interesting part was that the car drove much better after they fixed that problem. This being my first BMW, I had been driving it with the squeak and not realizing that performance was being hampered. The difference was remarkable. Anyway, I suggest you drive another manual E90, and drive it aggresively, and see if you notice any difference in performance. The one thing in your favour is the fact that your noise seems to be temperature related, so it may not be a mechanical issue. |
06-13-2006, 12:27 PM | #11 | |
Rep 296
Cheers,
________________________ 2006 BMW 330i Jet Black - Burl Walnut - Black Leather - 6MT Sport Package - Premium Package - Cold Weather Package |
06-13-2006, 02:37 PM | #12 | |
Rep 227
06-13-2006, 02:40 PM | #13 |
156
Rep 10,411
one month old no squeaks
2010 AW e90 328i: 6 speed, Black Leather, Dark Wood trim, ZPP, ZCW, ZVP,ZSP, Nav, Xenon
BMW Performance CF Rear spolier and Gloss black grills 2008 Candy White MKV GTI 2.0T 6 Speed Manul Gone 2008 AW X3 3.0si: 6 speed Returned 2006 AW e90 330i: 6 speed Dinan Stage 1 Returned |
06-13-2006, 10:12 PM | #14 | |
Rep 214
No mechanical issues with clutch or shifting .......
06-13-2007, 03:38 PM | #15 | |
Rep 6
Mine seems to be squeaking a lot lately, but only when warm. It gets worse the warmer it is. Oh, the problems. |
