      09-29-2008, 11:35 PM   #1
gan08
14
Drives: Fatty X5 and Pot-bellied 135
Storing the 1 for an extended period
I will be apart with my 135 for 4 weeks. Is there anything I should do before leaving her alone in the garage?
4 weeks without starting up and driving around, will the 1 be ok?
Any suggestion would be appreciated.
      09-30-2008, 12:18 PM   #2
Tom K.
Tom K.'s Avatar
124
Drives: '07 328iT, '13 Boxster
If you haven't been driving it much, you might consider hooking it up to a "Battery Tender" type charger as insurance. However, even this probably won't be necessary - as my E46 with it's 4 year old battery started right up after nearly 5 weeks while I was travelling in the 128i.
Tom
      09-30-2008, 12:27 PM   #3
PUREPHAZED
Helping thru Design
Drives: 2008 BMW 135i
Smile
In the manual it says if you will part your beloved for 90 days or more you need prep it for storage otherwise you will be fine.
M
      09-30-2008, 05:09 PM   #4
RobLS
29
Drives: M3 Coupe
a.k.a you're good
      09-30-2008, 05:31 PM   #5
gizmo
16
Drives: 135i
I parked my car for nearly 4 weeks with no problems... The only thing I did was make sure it had a full tank of gas to avoid any "condensation" issues. Probably overkill, but it was easy enough.
2008 135i Premium/Sport/Cold CA/HiFi
      09-30-2008, 07:07 PM   #6
scorcherjf
scorcherjf's Avatar
29
Drives: 2008 135i
2008 135i  [0.00]
Yea you're probably fine for a month. When I left my 330xi (with run flats) for a few months, I had to replace the tires when I got back because run flats seem to mold into a position and it can't be repaired so... take the wheels off if you go away for more than 3 months :smile:
Search this Thread:
Advanced Search
1addicts
