      08-27-2008, 09:00 AM   #1
jkp1187
Unindicted co-conspirator
66
Drives: to work, mostly.
Question Timing Belt
Is there a timing belt in either the N52 or N54 engines? If so, what is the recommended service interval? Thanks.
      08-27-2008, 09:24 AM   #2
atr_hugo
No longer moderate
atr_hugo's Avatar
No_Country
325
Drives: '13 135i
Chains.
      08-27-2008, 10:37 AM   #3
Lexington
Lexington's Avatar
53
Drives: 2008 135i Blue Water
Internal?
      08-27-2008, 10:43 AM   #4
My135
85
Drives:
Timing chain supposed to last for a very long time and does not required periodic replacement or service until it start slipping.
7/08 135 Coupe, Crimson Red, 6 SP, Sport, Taupe Lette/Aluminum. Performance Mods: JB4 on Map 5, BMS DP Fix V3, Injen polished intake, AR Catless DP, Maddad resonated mid-pipes, aFe exhaust polished tips, ST Suspension Coil Over and Hotchkis front sway bar. Others: BMS OCC, BT Scanner, Mud Flap. Next Mods: AA Front Strut Brace.
      08-27-2008, 11:15 AM   #5
atr_hugo
No longer moderate
atr_hugo's Avatar
No_Country
325
Drives: '13 135i
The chains are encased.
      08-27-2008, 11:18 AM   #6
neteagle
Drives: MBM 135i
A slipping time chain will likely destroy the engine because you are going to bend valves...unless you are itching for a new engine, replace the chain and chain guides before then :wink:
...I replace the timing chain at the 100,000 mile mark...
NetEagle
'11 335i Le Mans Blue, Saddle, Dark Glacier, Manual, M-Sport, Premium, CA, Harman Kardon, Heated Seats, iPod, High Beam assist, 35% tint, Stone-X, BMW Performance Exhaust, Shadow Grill, CF competition spoiler
      08-27-2008, 11:20 AM   #7
Mad Dragon
Mad Dragon's Avatar
27
Drives: 2010 GTI
If a timing chain ever slips, you've got some serious problems.
      08-27-2008, 11:38 AM   #8
gio
50
Drives:
How could a chain slip? I imagine it's something like a bicycle chain, right? A bicycle chain has to be pretty worn before it slips, nothing like the notched belt in many cars.
Waiting on a 2015 M235
      08-27-2008, 11:52 AM   #9
neteagle
Drives: MBM 135i
Over time, the chain will stretch, when that happens, the teeth will begin to wear, and before you know it, the stretched chain will slip over worn teeth...ka boom
NetEagle
      08-27-2008, 12:50 PM   #10
gio
50
Drives:
The owners manual that came with the car doesn't say anything about regular maintenance on the chain. What are we supposed to do?
My TTs manual said to change the timing belt every 115,000 miles I think.
      08-27-2008, 01:31 PM   #11
Lexington
Lexington's Avatar
53
To continue the bicycle analogy, with a bike you measure the chain and when it starts to show wear, by increased length, you change it to keep it from wearing down the teeth in the front chainring and rear gear cluster.
      08-27-2008, 06:12 PM   #12
IDBMW
IDBMW's Avatar
41
Drives: 2019 X3 M40i
I think there is a chain tensioner which is spring loaded to keep tension on the chain. Years ago I rebuilt and tuned MG engines and that is how MG did it.
It’s the timing belts that need to be replaced at 100K miles, chains last forever. Also, if you do not have a zero clearance engine and the timing chain slips the engine should not be harmed. If you have a zero clearance engine and the timing belt/chain slips the pistons hit the valves and ruin the engine.
2019 X3 M40i - Black Sapphire Metallic - Mocha Lather - 21" 718M wheels - Every option except Sun Shade
      08-28-2008, 11:36 AM   #13
Nixon
57
Drives: :
So does anyone know if either of these engines are "zero clearance engines"?
      08-28-2008, 11:44 AM   #14
imported_mega
No_Country
122
Drives: various bmw's
isn't everything zero clearance now?
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
Driving e82, e72, e85, R53 Gone but not forgotten..
1974 2002, many various 3s.
      08-28-2008, 03:13 PM   #15
1er junkie
18
Drives:
+1 lol
wheels have been sold!
      08-29-2008, 09:16 PM   #16
mikeo
Santa Fe Concorso
mikeo's Avatar
103
Drives: '11 M-sport 328i, '13 X1 28i
Yes, they are both zero clearance. Many past BMW owners have found this out by the dreaded "mis-shift" downshift that over-rev'ed the engine, floats the valves, and said valves impact the piston tops. Nasty (and very expensive) business.
Santa Fe Concorso - The Southwest's Premier Automotive Gathering.
Search this Thread:
Advanced Search
1addicts
