Tirerack
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > Anybody have pictures of some aftermarket 17" wheels?
      06-06-2006, 11:32 AM   #1
fueledbymetal
fueledbymetal's Avatar
129
Drives: 2024 G80 6spd, Cayman GTS 4.0
I'm thinking about getting a 325i am leaning towards 17" rather than 18" wheels in order to save weight. Does anybody have some pictures of an E90 with some aftermarket 17"s?
      06-06-2006, 05:30 PM   #2
06330i
fresher den you
06330i's Avatar
Poland
34
Drives: 2004 x3
2006 E90, 330i  [0.00]
mann get atleast 18"s or 19"s.
      06-06-2006, 08:29 PM   #3
icewatersoda
22
Drives: Black on Black E90
i'd keep it stock with 16" or 17"
2006 325i Jet Black (5-21-06)
      06-07-2006, 07:03 AM   #4
fueledbymetal
129
Originally Posted by Ethirtynine
Are you saving weight for racing purposes?
More for spirited driving. I just prefer the lightest possible wheel & tire combination to the "big wheel" look. I generally shoot for the smallest wheel to clear the brakes that have a 45 series sidewall or less. In the case of the 325i, a 17" wheel fits that spec.
I've already found a 16lb 17" wheel that will fit the e90, but I'm hoping to find something lighter. I'd like to shed about 10lbs per corner with a new wheel/non-runflat tire combo.
      06-07-2006, 01:43 PM   #5
MINNOW
Current E90 Fetishist
MINNOW's Avatar
Drives: '07 323i / '04 MINI Cooper
No pics, but I share your preference for the lightest practical weight wheel available.
In 17" a simple plug'n'play choice is the BBS RK which is only 1mm from stock offset and is hubcentric so hub centering rings will not be required.
Another option is the OZ Ultraleggeras in 17" x 8", but I do not know the centrebore for these, so hub centering rings may be required.
Both choices are around the 17 lb. range.
What may I ask have you found at 16 lbs.?
      06-07-2006, 02:16 PM   #6
fueledbymetal
129
The RK was actually one of the wheels I was referring to, but at 16.8lbs, I guess it's closer to 17lbs than 16lbs. Also weighing in at 16.8 is the Kosei K1 Racing, but it has a 40mm offset, so it would probably require a spacer.
The SSR Type C RS that the Tire rack has listed for the E46 weighs 15.9 lbs, but I'm not sure what the offset is so I'm not sure if it can be made to fit.
I wish the MOTEGI TRACK TRAKLITE 2.0 would fit because they weigh 14lbs but only cost $288/wheel!
      06-07-2006, 05:48 PM   #7
ska///235i
***** noob
ska///235i's Avatar
1369
Drives: 325xi>M235i>428GCx Mspor
2006 325xi  [0.00]
i have the utlraleggeras but 18s...do need center ring
2006 325xi (Sold)
2014 M235I (Current)
2015 428xi Gran Coupe (STB)
      06-07-2006, 06:01 PM   #8
dkizerian
Digital Ruler
Drives: 325i AW/Terra
Boy the ultraleggeras sure do make your car look very tall, and very short in length!!
But seriously, the e90 is NOT a light car and while going with a lighter wheel will improve performance somewhat, going overly light could just end up being costly.
      06-08-2006, 12:59 PM   #9
Pim
Pim's Avatar
Belgium
27
Drives: BMW 118 d sporthatch
162 elipsoide styling 17"
Check Enrico's wheels. Very nice !!!
http://www.e90post.com/forums/showth...ht=162+replica
      06-08-2006, 01:09 PM   #10
shragon
Moderator
shragon's Avatar
No_Country
497
Drives: BMW
17" bbs rg-r's...
      06-08-2006, 01:11 PM   #11
HRC
MAUI BUILT
HRC's Avatar
485
Drives: 2006 330i MT
2002 E46 325i  [0.00]
2012 E70 35i  [0.00]
To bad Volk doesnt make 17" applications for the e90. My last set of 17" SE37K's were 15lbs. forged monoblock.
Danny
Arctic/Blk Leather/Alum.Trim/MT/ZSP/Sunshades/Blk Lines/M3 Illuminated Knob/Alcantara Performance Wheel/M-E-Brake Handle/Euro Fog Switch/Koni Yellows/H&R Sport Springs/19" VMR V718's w/PS2 Tires/M-Tech Body Kit/Carbon Fiber Spoiler/Bimmian Interior Bulbs/OEM Eye Glass Tray/SSK/Alcantara Boot/Split Armrest/OEM Dual Rear Power Outlets/Rear Ashtray Delete/OEM Alum. Pedals/Osram 6000K/Brex Rings/LED Side Markers/BMS Power Box
