06-11-2008, 01:43 PM | #1 |
34
Rep 1,002
Alarm programing problem
So I took my 135 into the dealer to have it programed after I did the install and they said that they couldn't communicate with the alarm module. After double checking all the installation, they detirmined the module must be bad. I asked them if they had v29.02.00, they said they had the latest software and said they could communicate with the other modules in the car. I am currently trying to get to the bottom of the issue so any thoughts would be appreciated. I bought the module from Tischer who advertises on this site and I am trying to contact them about what they think.
The module appeared to be new in box, so I would be surprised if it really were a bad module. Thanks.
"Don't run, you'll only die tired" ~ Gunship Pilot
06-11-2008, 01:53 PM | #2 |
51
Rep 226
does your alarm light blink on your mirror? One way you can test it and I didn't even know about it until I did it by accident on saturday is open the windows, shut the door, and lock the car. Give it a few minutes, and then stick your hand into the car and the alarm should go off. My did and I was like woo wait a minute I didn't think it would work until it was programmed.
06-11-2008, 02:03 PM | #4 |
51
Rep 226
mine's not programmed either and won't be until tomorrow hopefully. Try the window thing and see if that works maybe it will and maybe it won't, I was suprised that mine did.
06-11-2008, 02:10 PM | #5 |
34
Rep 1,002
I now have the module sitting on my couch, and won't be able to reinstall for a little while otherwise I would, thanks for the heads up though I will try it when I put it back in. I also have a January production car if that would make a difference.
06-11-2008, 06:58 PM | #8 |
377
Rep 5,730
Drives: BMW i3 rex
Garage List 2018 I01 i3s | CURRENT [0.00]
2018 G01 X3 | CURRENT [0.00] 2017 I01 i3 | SOLD [0.00] 2017 F48 X1 | SOLD ... [0.00] 2016 I01 i3 | SOLD [0.00] 2017 F22 M240 | SOLD [8.00] 2016 F25 X3 diesel ... [0.00] 2006 E60 550 | SOLD [6.00] 2011 E90 335 | SOLD [8.66] 2012 E82 135 | SOLD [5.50] 2011 E82 1M | SOLD [7.94] 2007 E85 Z4M| SOLD [4.50] 2003 E53 X5 4.6is S ... [9.00] 2008 E92 328 | SOLD [0.00] 2008 E82 135 | SOLD [0.00] 2008 E90 335 | SOLD [0.00] 2003 E46 M3 | SOLD [7.50] 2006 E90 330 | SOLD [10.00] 2003 E46 330ZHP | SOLD [0.00] |
there's a know problem with programming the OEM alarms. BMW is working on a solution to be sent to dealers on that issue. As of last week BMW has not released the fix yet, ETA is still about a month away when i called the shop foreman to check on it....
06-12-2008, 09:11 AM | #10 | |
4449
Rep 7,594
Drives: '19 M2C
What version of software does your dealer have? These are the versions available according to Mad Dragon: Current software version: 29.02.00 New software version: 30.00.00
www.ReTuneTheDeTune.com
2019 M2 Competition (Sunset Orange) |
06-12-2008, 11:23 AM | #11 |
Rep 102
I took my 135 in to get it reprogrammed about a month ago. They had it for 3 days and they could not get the car to accept new programming. They opened a PUMA case on it and were told by BMWNA that no dealers should attempt 1 series programming until further notice. I checked with the BMW Performance Center and they said the same thing. Hard to believe that AG would let such errors happen. I have heard that some cars are dead in the water at dealers - can't be programmed - can't start.
06-13-2008, 11:02 AM | #12 | |
4449
Rep 7,594
Drives: '19 M2C
06-13-2008, 11:29 AM | #14 |
Rep 102
No, mine is still not programmed. The OEM alarm parts are in the car and I have the blinky light, but that is it. Also there is a suspicion that the programming they did try deleted my automatic parked car ventilation (since that is gone now).
06-13-2008, 11:31 AM | #15 |
4449
Rep 7,594
Drives: '19 M2C
I still haven't gotten my alarm programmed either. I have an appointment for next Wed.
Do you guys know what version of the software your dealers have?
06-13-2008, 11:50 AM | #17 |
4449
Rep 7,594
Drives: '19 M2C
Great...so they must have tried v30.xx.xx and it didn't work. I might as well cancel my appt. for next week.
06-13-2008, 12:32 PM | #18 |
51
Rep 226
How does the parked car operation work? Is that on all of the 1 series? Is that to blow the hot air out of the car? My boss's 550 I does it but I don't know if the 128 does it.
06-20-2008, 12:49 AM | #19 |
81
Rep 1,264
Drives: 2010 Dinan S3 Z4-35i
No Audible Confirmation when locking and unlocking...
When I had my car delivered to me I made sure the dealership add the factory alarm. I suppose it works as they mentioned, but they said they cannot get the car to have the BMW audible confirmation beeps when arming and disarming since they do not yet have a software available (progman) that can add that feature yet. Is this true?
Does anyone out there have the factory BMW alarm installed and not able to get the audible confirmations yet? Please let me know if there is a fix or an updated software that I can relay to my local dealership. Right now only the parking lights flash on and off when locking and unlocking. My 650 came with an alarm standard and has the audible confirmation and can be turned off via the iDrive. I checked on my 135 iDrive, but did not have that option. This was the first place I checked.
2015 BMW i3 REX
06-20-2008, 08:14 AM | #20 |
34
Rep 1,002
Have you checked to see if your alarm is actually working? That is what my car does without the alarm and with hardware installed the clown nose lights up too. I would roll your windows down, lock the car/arm alarm, then wait a couple minutes and stick your arm in the window and wave it at the motion sensor and see if it sets off the alarm.
06-20-2008, 09:53 AM | #21 |
81
Rep 1,264
Yeah I tested it out that way and the alarm does go off. Just no audible beeps when locking and unlocking.
2015 BMW i3 REX
