06-10-2008, 09:28 AM | #1 |
125
Rep 404
Drives: 16' X5 M-Sport / Space Gray
Best brand for window tint?
What do you suggest? I'm looking for "the good stuff"
Tint that will not turn purple or bubble and also blocks out heat as well as light? What's the best! |
06-10-2008, 09:56 AM | #2 |
Rep 56
Drives: 2014 LSB 335i xDrive M Perf.
06-10-2008, 10:03 AM | #3 |
Santa Fe Concorso
103
Rep 2,984
Stay away from metallic based products if possible. Ceramic based tints are reputedly superior for GPS, SatRad, and Radar signals.
Santa Fe Concorso - The Southwest's Premier Automotive Gathering.
06-10-2008, 10:09 AM | #4 | |
141
Rep 1,401
Just had F1 Pinnacle installed yesterday. Great stuff. |
06-10-2008, 11:42 PM | #5 | |
25
Rep 162
Drives: G87 & E88
That's the good stuff.
06-11-2008, 06:51 AM | #8 |
81
Rep 1,075
That's what I'm currently trying to have installed because it's ceramic and won't block cell signals at all. They don't have a certified installer in my area but the factory might allow one of their local installers of another product line install it for me. Will it look good on a black car? It rejects nearly as much heat as huper optic ceramic film but has fewer layers (easier to install and less clearance issues).
Ordered 4/7/08, Delivered 5/15/08, Sold, but not forgotten.
06-11-2008, 09:00 PM | #9 |
BMF
Rep 84
I went with Huper Optik Ceramic 40 all around. I compared all the ones listed above, and they all seem to come highly recommended with lifetime warranties against color change, bubbling, etc. Huper Optik appeared to have the best heat rejection when comparing similar light transmission specs (I didn't want a real dark limo-look). It wasn't cheap, though - $350.
135i
SGM, Coral Red Leather, Gray Poplar Trim, 6MT, Sport pkg, Premium pkg, Cold Wx pkg, Comfort Access, Premium Hi-Fi, Satellite Radio Delivered May 12th! |
06-11-2008, 09:13 PM | #10 | |
81
Rep 1,075
06-12-2008, 07:16 PM | #11 |
BMF
Rep 84
135i
06-12-2008, 08:13 PM | #12 |
91
Rep 1,168
Does anyone know right off the bat--which has better UV blocking: Formula One or Huper Optik? And are they full-spectrum protection or just UV-B shielding?
06-12-2008, 08:39 PM | #13 |
25
Rep 162
Drives: G87 & E88
If you wear polarized sunglasses make sure you look at the tint that you want with them on. I had Huper Optik on my last car and it looked like crap through the polarized lenses. Rainbows, stripes and such. Not impressed with the Huper film at all.
06-13-2008, 03:16 AM | #14 |
91
Rep 1,168
Thanks for pointing that out Texas. I wear polarized shades.
So: F1* > Huper Optik > 3M ? *When using Pinnacle Series or UV Shield To those who used F1: How much did you pay? I'm aware Huper Optik is on the pricey side. |
06-14-2008, 06:54 PM | #16 | |
141
Rep 1,401
It's a little pricier than some of the other tints but it appears to be a better material and it came with a lifetime warranty. The shop will repair or replace the tint if anything happens including bubbles, scratches (even if I scratch it out of my own stupidity), broken window replacement, etc. |
06-14-2008, 07:25 PM | #17 |
25
Rep 162
Drives: G87 & E88
$249 for the F1 Ultimate. I liked the Ultimate because it is less reflective than most. Plus on the 'vert I don't have to worry about the tint interfering with the rear window antenna signal. I get a nice big whip antenna on the driver's back fender.
Like lib, I would buy the Pinnacle on a Coupe.
06-14-2008, 08:08 PM | #18 |
77
Rep 1,376
Drives: 1988 M3, 1990 M3, 1998 M3/4
Garage List 1998 BMW M3/4 [10.00]
2011 BMW M3 Sedan [9.28] 1988 BMW M3 [9.40] 1990 BMW M3 [10.00] 2008 BMW 135i - sold [0.00] 2003 BMW M3 - sold [0.00] |
I've got 3M Crystalline on my car. The installer used to do Huper and says this is much better stuff when it comes to performance, but also easier to put on without flaws. I really like mine and it has made a huge difference in cooling down the car.
1988 BMW M3 - Hennarot/Black
1990 BMW M3 racecar - Diamond Schwarz/Black 1998 BMW M3 - Alpine White/Mulberry 2011 BMW 328i racecar - LeMans Blue/Black |
06-14-2008, 09:34 PM | #19 | |
81
Rep 1,075
3M™ Crystalline Automotive Window Films
"Huper ceramic 30 visible light transmission 34% visible light reflectance 11% shading coefficient 0.47% total solar energy rejected 61% infared light rejection 85% UV light reflectance 99.9% Huper ceramic 40 visible light transmission 42% visible light reflectance 9% shading coefficient 0.53% total solar energy rejected 55% infared light rejection 80% UV light reflectance 99.9% 3M™ Crystalline Automotive Window Films 40 (rear window limit in VA) 39% Visible Light Transmitted 59% Total Solar Energy Rejected 66% On Angle† 97% Infrared Rejected†† 50% Solar Heat Reduction 6% Visible Light Reflection Int. 7% Visible Light Reflection Ext. 99.9% UV Rejected 56% Glare Reduction †TSER On Angle calculated at 60 degrees ††IR for wavelength range of 900-1000 nm Huper ceramic 50 visible light transmission 50% visible light reflectance 10% shading coefficient 0.59% total solar energy rejected 49% infared light rejection 68% UV light reflectance 99.9% 3M™ Crystalline Automotive Window Films 50 (front window limit in VA) 50% Visible Light Transmitted 56% Total Solar Energy Rejected 63% On Angle† 97% Infrared Rejected†† 46% Solar Heat Reduction 7% Visible Light Reflection Int. 8% Visible Light Reflection Ext. 99.9% UV Rejected 43% Glare Reduction †TSER On Angle calculated at 60 degrees ††IR for wavelength range of 900-1000 nm " Quick Summary: Comparison of the 40 tint: total solar energy rejected (3M: 59% / huper: 55%) infared light rejection (3M: 97% / huper: 80%) Comparison of the 50 tint: total solar energy rejected (3M: 56% / huper: 49%) infared light rejection (3M: 97% / huper: 68%) It appears 3M performs better.. not to mention I have a 3M installer in my local area. http://www.huperoptikusa.com/pdf_doc...DUCT_RECAP.pdf http://solutions.3m.com/wps/portal/3...ineWindowFilm/
06-15-2008, 07:30 PM | #21 |
81
Rep 1,075
Not really. I looked into having formula one installed but the nearest installer is over 100 miles away. The factory rep said they might have their local installer of another product install it. I never heard back from him.
Here's forumula one pinnacle data: Product / UV Protection / Heat Rejection / Glare Reduction Pinnacle 50 99.5% _____ 43%___________ 44% Pinnacle 35 99.5% ______50%____________ 60% Pinnacle 15 99.5% _______59%____________ 81% Pinnacle 05 99.5%_______ 61%____________ 94% http://www.formulaone.com/pinnacle.htm It appears huper and 3M perform slightly better than formula one pinnacle (blocking heat).
06-16-2008, 04:24 AM | #22 |
91
Rep 1,168
3M seems superior! The odd thing is, I've read many recommendations for Huper Optik, although it offers only a 10-year warranty. There must be something better that Huper Optik has over 3M. Hearing about the problem with polarized eyewear is a let-down though. Formula One and Solar Gard provide lifetime warranties. How is 3M's warranty? If anyone knows, is it free of the polarized problem?
