05-24-2008, 09:47 PM | #1 |
23
Rep 453
New owners please check!
Had a look at the battery and found a wire just floating around not attached to anything?:iono: It has a plug attachment on the end but nothing in sight that it would be attached to. It branches off a similar wire that attaches near the +ve terminal. Can any new owners please have a quick look to see if it is the same in their cars. Cheers.
06-09-2008, 09:34 PM | #6 |
Rep 95
Could it be used to isolate the car alarm - kris already mentioned it.
I was wondering if its not actually connected...is it attached to a 1 series with optional alarm...they dont come preinstalled.:iono: |
06-09-2008, 09:44 PM | #7 |
13
Rep 814
I'd say that's definitely a 'wire up' for an optional extra which you don't have installed on the car :smile: unfortunately I would have no idea which extra that is...:iono:
Most makes actually fit the full array of wiring looms to all the variants of a particular model and then just wire up what the individual car has installed. I've stripped alot of my previous cars for various DIY installs and found this to be the case with all of them |
06-10-2008, 03:37 AM | #9 |
Disillusioned bourgeois capitalist pig!
21
Rep 488
Yes i too have the dangly wire. Was suggested to me that it relates to the front parking sensors if fitted. A mystery.......
You can lead a fool to knowledge but you cannot make him think!
06-11-2008, 07:48 PM | #10 |
13
Rep 814
06-11-2008, 08:05 PM | #11 |
2146
Rep 10,176
I have that wire, but it's plugged into the negative battery terminal. Pics coming...
edit: went out to garage took pic and added: |
06-11-2008, 08:19 PM | #12 |
23
Rep 453
That battery set up is different to ours in Australia. I wonder if we miss out on the efficient dynamics "on demand" battery charging?
06-11-2008, 08:28 PM | #13 |
2146
Rep 10,176
Dunno.
The battery is the same (they both show part number 118668-10), but that red/black add on assembly (distribution block) is different on your car. If you look at this picture, you can clearly see that there is a different distribution block for cars equipped with iDrive (which I do not have), but i do have premium audio, which may be what those wires are for.. to go to the more powerful amp. |
06-11-2008, 08:42 PM | #14 |
2814
Rep 7,637
I have the Pro Nav and the standard sound system..Still have the loose wire..
So you could be right.. Who has the Hi fi upgrade to check...Raj..Kris?? |
06-12-2008, 12:51 AM | #16 |
23
Rep 453
I have 6MT with HiFi upgrade (logic 7) and don't have nav.
06-12-2008, 05:39 AM | #20 |
Rep 95
Ladies,
supposedly the mystery wire is...."for the battery isolation switch, which is fitted to the BMW 1series during transportation of the vehicle to Australia". Straight from the dealers guy... Mystery solved? |
06-12-2008, 05:48 AM | #22 |
Rep 95
