04-19-2008, 08:05 PM | #1 |
40
Rep 1,657
how does the bluetooth work?
Ok, i read the manual but i'm having issues. my phone connects and i can dial my contacts through the car (they show up in the car). BUT
1) when i'm receiving a call, the name of the caller doesn't show up, instead i see ****. WTF? 2) i can't dial my contacts by voice. in the manual it says i have to impute them into the car's phone book. the manual says the command to start that function is "store name." "store name" has no effect. finally i figured out that "store entry" works. So the car asks me the name, i give it. The car then asks me the number. I give the 7 digit number, the car repeats it and then says "continue." and that's where i'm stuck. it keeps thinking there's more numbers. How do i finish the function and store the name? THANKS
"KOPEYKA" /// Titanium Silver / Black Leather / Gray Poplar / Sport Package / Premium Package / 6MT / Feb 08 Production |
04-19-2008, 11:09 PM | #2 | |
Rep 146
1) Is your contact in different language? Because it only shows Alphabets and Numbers in the contact.
2) Once it repeat the number, then say 'Dial'. Quote:
2013 - M135iA - Apline White
Year One - 135i - Monaco/Lemon/Gloss - Sport/Prem/Cold/iPod/HiFi/HD/C.A. |
04-20-2008, 02:19 AM | #4 | |
40
Rep 1,657
04-20-2008, 06:30 PM | #5 |
40
Rep 1,657
i think i found a list of voice commands for non-idrive cars. haven't tested it yet but have a good feeling about this. The command i was looking for, i believe was "save." the "store" command listed in the manual doesn't work in my car.
Dialing a Telephone Name You Say: Voice Output >> Dial Name << Please speak Name >> << Do you wish to dial >> Yes << Dialing >> No << System Off Dialing a Telephone Number >> Dial Number << Please Speak Number >> One, Eight.. << One, Eight, .. >> Dial Number << Dialing >> Correction << One, …. {The last number entered is removed on p >> Delete << Please speak the Number {You may start again} Cancel voice input at any time >> Cancel << System off >> Clear << System Off Storing a Telephone Number: >> Save Name<< Please Speak the Name >> XYZ << Please repeat >> XYZ << Please Speak the Number >> One, two << One, Two .. >> Save << The Name and Number are saved >> Correction << One, …. {The last number entered is removed on playback} >> Delete << Please speak the Number {You may start again} Deleting a Telephone Number: >> Delete Name << Please speak the Name >> XYZ << Would you like to delete XYZ >> Yes << Name and Number are deleted >> No << System Off Clearing the entire phonebook >> Delete Phone Book << Would you like to all entries in the phoneb >> Yes << Are you sure ? >> Yes << The Phonebook has being deleted >> No << System Off Dialing a number from Memory: >> Dial Name << Please speak the Name >> XYZ << XYZ, are you sure ? >> Yes << Dialing … >> No << System off Reading out the phonebook >> Read Phonebook << (Reads out enteries) >> Dial << Dialing {After a name has being read} Redial last number used: >> Redial << Dialing
04-20-2008, 08:17 PM | #6 |
Car'a'carn
472
Rep 751
you know the Blackberry has built-in voice dialing.. maybe its conflicting with the car voice dialing.. just something to think about
04-20-2008, 09:06 PM | #7 |
40
Rep 1,657
i just tried the commands above and it worked perfectly. stored a couple of voice entry's in bmw phonebook using the "save" command and now i can dial them.
Also, figured out the problem with the names not showing up when receiving a call - I was getting calls from "private" or "restricted" numbers. so even though i had them in my contacts, they show up as private on my blackberry, and on bmw they show up a ****.
