Spark plug help needed, 328i.
05-07-2024, 03:47 PM | #1 |
44
Rep 221
'08 328i. Bought certified 4 yrs. old. Replaced original plugs, DENSO IRIDIUM SK20R11 at 50K miles with NGK R5. Now at 90K+ thinking about replacing the plugs as MPG is dropping and I use Techron for the injectors. Coils replaced at 50K miles.
Now I noticed that the thread length of the original SK20R11 is appx. 5/8" and the NGK R5 thread length is a full 1". No piston slap and car running fine for 40+ miles. What plug would you suggest and thread length? Thanx, Mikey |
05-07-2024, 04:47 PM | #2 |
1085
Rep 1,689
I am not sure what NGK R5 is. But SK20R11 does not sound like a correct plug. It is not listed for the application on Denso's catalog.
Denso's catalog lists SK20HR11, and NGK's catalog shows a platinum plug PLZFR6A-11S (NGK #5987). Looks like BMW went cheap and switched to platinum with a shorter (60K mile?) interval? My 07 gets NGK long life iridium ILZFR6D11 (NGK #1208). Besides the spark plugs upstream oxygen sensors should be considered if they have >100K miles. https://ngksparkplugs.com/en/part-finder https://www.densoautoparts.com/part-...ehiclePartNum= |
johnnyorange58.50 |
05-08-2024, 04:42 PM | #5 |
Cometh
1093
Rep 1,309
Drives: Boy's Soul
Take your pick:
BOSCH FR7NPP332 - double platinum, 80k mile life NGK PLZFR6A-11S - double platinum, 90k mile life NGK LZFR6AP11GS - platinum center only, 40k mile life |
05-09-2024, 07:01 AM | #6 |
175
Rep 345
Never heard of an NGK R5?? Is that a mower plug..lol.
Put the correct stock Bosch plugs or upgrade to NGK Iridium. Replace the coils too with Eldors. fcpeuro.com |
05-09-2024, 11:05 AM | #7 | |
26
Rep 53
I actually did some research on this, if you are running the updated coils (Delphi 12138616153 / Bosch 12137594937), these two NGK options are the OE plugs, I personally run 11S because weirdly it's cheaper than 11GS in my region.
Reference: 12120032137 = NGK ILZFR6D11 Center electrode: iridium size: 0.6mm Ground electrode: Platinum Overall Height: JIS (53mm) Longevity: 100k Miles 12122158253 = NGK PLZFR6A11S (up to 2009) Center electrode: Platinum size: 1.0mm Ground electrode: Platinum Overall Height: ISO (50.5mm) Longevity: 90k Miles 12120037663 = NGK LZFR6AP11GS (since 2013) Center electrode: Platinum size: 1.0mm Ground electrode: Nickel Overall Height: ISO (50.5mm) Longevity: 40k Miles |
The Nightman1093.00 |
