05-04-2024, 09:27 PM | #1 |
Rep 1
Odd engine code M240 2019 xdrive
Anybody know what this top engine code means? It’s not well documented so am a bit unsure of any fix. It comes up sparadically not sure what I’m doing to cause it unfortunately. Thanks in advance!
05-04-2024, 11:37 PM | #3 |
123
Rep 210
You can look up fault codes here:
https://bmwfault.codes/ I am not an expert but it may be a problem with the sensor or there is a problem that is causing excess emissions. The second code suggests a possible electrical issue. Do you have any devices that could be causing a drain? https://bmwfault.codes/XMLDiagView?d...kAMgA2ADAANAA= https://bmwfault.codes/XMLDiagView?d...YAMAA2ADAANAA= |
