Broke a Lug Bolt!
05-27-2006, 07:45 PM | #1 |
Let's See...Bimmer or Lotus today?
15
Rep 30
Broke a Lug Bolt!
Ok...I was installing my new 20" wheels. When on the final bolt (OEM bolts) of the last wheel, I broke a lug bolt while torquing. The head of the bolt popped completely off. My torque wrench was set at 88 ft. lb. Has this happened to anyone else? I took a chance and called roadside assistance thinking that they might be able to send a tow truck driver that was knowledgable enough to be able to remove a broken bolt - no such luck. Roadside assistance advised me that all they could do would be to flatbed the car to the dealer. Well the dealer is of course closed until Tuesday, so that is not an option. Should I just wait until Tuesday and have the dealer take care of it or can somebody provide an easy do it yourself solution to remove the broken bolt? Would the car be safe to drive with only four lug bolts or should I have BMW tow the car? Will the dealer blame the break on me and have me pay for labor? :mad:
The good news is that the wheels look great! TIA! |
05-27-2006, 07:52 PM | #2 |
39
Rep 647
wow, first i've heard of a broken bolt. if u did torque it correctly i would have to say it was a bad bolt. how far is dealer from ur house? i wouldn't drive it if i were u. just call them first thing in the morning ask what u should do.
05-27-2006, 07:54 PM | #3 |
119
Rep 2,909
Your car is fine with only 4 bolts. You can actually fix it your self very easily. Just take the other 4 bolts off and slide the rim off with the broken stud still in place. Once you have the rim removed, you can use somekind of Vicegrip type wrench to grab onto the broken stud and loosen it. If it is broken too far into the hub you may want to take it to a professional. Call your local Discount Tire and ask them where they send cars when they break bolts (I've had it happen to me plenty of times).
Situations like this are the exact reason cars use lug-bolts instead of lug-nuts. |
05-27-2006, 07:55 PM | #4 | |
18
Rep 387
what he said no need to go to the dealer!!
2006 BMW 330i - Jet Black - Terra - Burl Walnut - Premuim Package - Sports Package - Fold Down Seats - Heated Front Seats - Strut Brace - Sunglass Tray - Carbon Fiber Front Lips - Alarm - Blacklines - ACS Roof Wing - Breyton Trunk Spoiler - 19" Breyton Spirits wrapped in Michelin PS2
05-27-2006, 08:49 PM | #5 | |
15
Rep 30
I took a peek to see how much of the stud is left sticking out of the hub. One, maybe two threads. Hopefully it'll be enough for a vice grip to grab on to. I always spray WD-40 before replacing lug bolts so hopefully that'll help the broken stud turn. My vice grip seems to have walked off by itself. Here comes another trip to the Home Depot. I'll let you know if it works! Thanks voltron1011.
05-27-2006, 08:55 PM | #6 |
66
Rep 840
worse comes to worse you take a dremel and cut a line ontop of the head and use a hefty flat headed screwdriver and turn it out.
And why may I ask are you using OEM lugs for aftermarket wheels? Arent OEM bolts typically ball seat and aftermarket are cone seats? |
05-27-2006, 09:01 PM | #7 |
17
Rep 279
Isn't 88ft.lbs a little much!?!?!
2007 E90-328i (Sparkling Graphite w/Black Leather & Alum)
ZPP // ZSP // ZCW // 205 // 322 // 417 // 507 // 522 // 4AD |
05-27-2006, 09:53 PM | #10 | |||
15
Rep 30
Thanks for everyone's advice! I a happy camper now and have returned to normal size and color. Last edited by 330ionMaui; 05-27-2006 at 10:10 PM.. |
05-27-2006, 11:47 PM | #11 | |
MAUI BUILT
485
Rep 7,781
Drives: 2006 330i MT
Danny
Arctic/Blk Leather/Alum.Trim/MT/ZSP/Sunshades/Blk Lines/M3 Illuminated Knob/Alcantara Performance Wheel/M-E-Brake Handle/Euro Fog Switch/Koni Yellows/H&R Sport Springs/19" VMR V718's w/PS2 Tires/M-Tech Body Kit/Carbon Fiber Spoiler/Bimmian Interior Bulbs/OEM Eye Glass Tray/SSK/Alcantara Boot/Split Armrest/OEM Dual Rear Power Outlets/Rear Ashtray Delete/OEM Alum. Pedals/Osram 6000K/Brex Rings/LED Side Markers/BMS Power Box
05-28-2006, 12:03 AM | #12 | |
15
Rep 30
Aftermarket lug bolts?
05-28-2006, 12:06 AM | #13 | |
66
Rep 840
well that's not always the case...wrong lug seat on some wheels means you wont always maintain proper torque specs. And add to that often times when you go different offset/widths you end up having to use longer lugs that's even more critical.
Glad you got the busted lug out |
05-28-2006, 12:34 AM | #14 |
Rep 172
Interesting article on mounting aftermarket wheels: "As a side note, it is actually possible to break lugs if you go without the proper hub adapters. The hubs themselves are what are supposed to bear the weight of the car while the lugs keep the wheel secured. Without the adapters, it is now the lugs that are bearing the full weight of the vehicle and they may not be up to the task. Breaking lugs isn't an especially common occurrance but it's certainly not unheard of either."
http://www.wildweasel.ca/j-body/HowTo/wheelinstall.asp |
05-28-2006, 01:15 AM | #15 |
16
Rep 229
good u got the lugs out. now post pic of your car with the rims
Sneeky4life
'06 330i, SG, ZSP, ZPP, Blackline Taillight, 20" Vossen CV3, M3 front and rear.. |
05-29-2006, 03:53 AM | #16 | |
Got Seoul?
116
Rep 2,862
Drives: 2012 535i MSport
Can you say Alooooha?
[SIGPIC][/SIGPIC] |
04-26-2012, 07:07 PM | #17 |
Rep 67
Sorry if this is a stupid question, I have a 2007 335xi and I recently got my wheels changed. I didn't install them myself I had a shop do it, today I went to tighten the wheel and noticed one of the lug nuts was GONE!!! so my searching go me here and from what I am hearing my car uses lug bolts and not lug nuts. When I look into where the lug bolt should be there doesn't seem to be anything in there. The car has been driving fine, no shaking or anything so maybe the lug bolt just fell out? I'm bringing the car back to the shop tomorrow morning, if nothing is stuck in my hub would I simply just need a new lug bolt?
2007 E90 335xi|Monaco Blue|Black Leather|Alum Trim|Steptronic|Sport w 18" 162s|CA|PDC|Heated Seats
04-26-2012, 07:47 PM | #18 | |
3441
Rep 79,211
Drives: C6 Z06, 09 335i, 10 335xi
Either they didnt put 1 in or they forget to tighten them down enough and one came out. Assuming it didnt snap inside you can just replace it with a new one. |
04-26-2012, 07:54 PM | #19 | ||
Rep 67
04-26-2012, 08:58 PM | #20 | |
37
Rep 432
