BMW M3 and M4 - The Icons
home
Technical Sections Mechanical Maintenance: Break-in | Oil & Fluids | Servicing | TSB | Recalls
      03-12-2024, 08:15 AM   #1
ahgil
24
Drives: G80 M3
G80 M3 - Oil part number
Hi All,
I tried to search but there are too many different OEM oil available. I am planning to change the transmission oil, rear diff and transfer case oil on my X drive. I can see online BMW OEM has lifeguard and ATF3+ for ZF transmission, which Rear diff, i see it has Hypoid Axel G4 G3 and even G5. And there is no information of what oil to use for the transfer case. Has anyone been able to share me the information on part no. or which oil i should use if i intend to use BMW OEM oil.
Thanks
Gilbert
      03-13-2024, 10:20 AM   #2
ahgil
24
Drives: G80 M3
Sad, I think many people either have not reach the service milestone or like me, don't have any detail. I tried to do more search and here is what I have. Hopefully this can help anyone who will need to change their oil soon as well
Transmission - ATF3+ part no. 83222289720 need 7 litre
Rear Diff - Hypoid Axel Fluid G4(LSD) part no. 83222447362 need 1.5 litre
Transfer Case - DTF1 part no. 83222409710 need 1 litre
Front Diff - Hypoid Axel Fluid G5 part no. 83222471487 need 1 litre
Of course if my information is not correct, feel free to correct me. By far this is the only information i can find for our G80
      03-13-2024, 10:31 AM   #3
SwankPeRFection
1220
Drives: S4
Or they don’t run BMW fluids…. I don’t.
      03-13-2024, 10:55 AM   #4
kgelfen360
kgelfen360's Avatar
2217
Drives: BMW
How many miles you got that u need to change the fluids. Transmission fluid change is only if service in transmission performed according to bmw.
      03-13-2024, 11:46 AM   #5
forcefed
forcefed's Avatar
2566
Drives: .
Where'd you get the 7 liters from? My service manual says min 9.35L
      03-13-2024, 09:44 PM   #6
ahgil
24
Drives: G80 M3
Would you mind share the service manual that mention that, cause from all the place i search, i see it uses 7 litre.... not sure if G80 is very different.
      03-14-2024, 08:49 AM   #7
forcefed
forcefed's Avatar
2566
Drives: .
Here you go.
g80
