BMW X1 (F48) and X2 (F39) Forums General BMW X1 Forum (F48) BMW X1 F48 2BA100 Diesel particulate sensor: Electrically faulty
Thread Tools
      03-01-2024, 05:50 AM   #1
zeljko2
Croatia
32
Drives: BMW X1 sDrive 18d F48 4.2019.
Greeting.
I own a BMW X1 F48 4/2019. year 18d B47B. with which I did 46,000 km.
So far I have had changes to the DPF filter sensor and now the same failure has occurred again with the same error.
Error recorded on Biemerlink diagnostics: 2BA100 Diesel particulate sensor: Electrically faulty (Exhaust-gas sensors / sensor for NOX, Part number: 13628596295).
They told me at the service center that my driving regime with short distances was to blame. I consider this not an acceptable explanation because I know a lot of people with different brands of cars who also do low kilometers and do not have such problems.
Does anyone have an opinion on why this is happening and what could be the cause?
I thank you.
      03-01-2024, 06:43 AM   #2
mrpingu
Norway
625
it is partly true, if you drive a lot’s of short distances it is not good for the DPF. The DPF regenerates if you have longer trips on the motorway (atleast 30min drive after the motor has come to temperature)
However this error is the electronics not the DPF itself but it could be a relation if the DPF is full What does BimmeLink say about the DPF? Try to force regenerate with BimmerLink when you are driving a longer trip.
Then drive 1 gear lower then you would normally do and/or use sport mode for that.
Sadly but true, people buy diesel cars for the wrong reasons. With all the environmental requirements Diesel engines have become more complicated, DPF is one part of that and it is known that DPFs don’t like short trips.
Only drive short trips? Don’t buy a diesel, it will NOT be cheaper in the end. diesels also have a slower warm up, that was even before the whole DPF was a thing and that is also the reason why diesel need longer trip/ otherwise you get more carbon build up in the engine. Same applies to the DPF, it needs good temperature to burn clean!
      03-01-2024, 07:35 AM   #3
zeljko2
Croatia
32
Thank you for your reply.
I understand what you mean, but circumstances have changed.
My wife and I became pensioners in the meantime and we don't drive as much anymore. Now we use the car to go shopping.
I note, I know a lot of people who have a similar need for a car, but they don't have these problems. Now I understand why BMW gives a modest warranty of two years. That's because he doesn't trust his car to last 5 or more years without breaking down, as for example KIA gives a 7-year warranty.
Could it be a problem in the ECU, wiring, fuel? Should you use additives for the DPF filter like Datacol? What is the best additive?
Thank you.
      03-01-2024, 03:16 PM   #4
mrpingu
Norway
625
Like advised, I would start with a forced regeneration.
If the problem continues to exist I would follow the error message which mentions,that the sensor is faulty electronically. Thus replace it, maybe with a used unit to save some costs. As this is not an error I have seen a lot so it maybe just bad luck, sometimes things break.
Personally I don’t believe in additives, more in short interval oil change, including gearbox and other maintenance. The default BMW 30k KM oil interval is waiting for the car to break after warranty. Almost all mechanics agree that 20k km is really the maximum interval you should do. Preferably 15k or even down to 10k, the 30k KM interval BMW uses is just ridiculous.
You mention that other people have the same needs and I can imagine to that, but are all those people driving diesel engines?
Your driving pattern changed, why not try to change your car? The X1 comes in both gasoline and diesel versions, what about switching to gasoline version of the car you have now? Maybe try to find similiar age, options and mileage?
I drive Diesel now because I drive 30k km a year, but before when I was doing lots of small trips I also managed to break a cheap car (Peugeot partner with 1.6 diesel engine) exactly due to too much small trips. So my advice, with nowadays diesel engines, get rid of it unless you are a match with the driving pattern that is required with modern day diesels. If not, gasoline engines are the better choice.
But my hunch is that you “just” have a faulty sensor. Given the error message.
      07-14-2025, 03:33 PM   #5
zeljko2
Croatia
32
Hello everyone.
I read somewhere on the Internet that people who have similar problems solve them by installing a spacer (extension) approx. 30 mm away from the direct flow of exhaust gases. Does anyone have any information on this?
These are the measures:
Total length 40 mm
Outer diameter Ø24 mm
Bottom thread M22x1.5, 10 mm
Nut Wrench 24 mm, thickness 7 mm
Top thread M22x1.5, 10 mm
Bottom hole Ø7.5 mm, 20 mm
Top hole Ø10.5 mm, 20 mm
Material: Inox 304 or 316 (recommended due to resistance to temperature and corrosion)
Can someone who understands this case give their opinion?
Thanks.
      07-25-2025, 01:12 AM   #6
gorgeto
Drives: Bmw 325d
Did you solve the problem? I have exactly the same problem?
Any solution?
      07-25-2025, 03:26 AM   #7
zeljko2
Croatia
32
Any solution?
I haven't solved the problem. I'd like to hear the opinion of someone who has solved it this way, but no one is responding. If you solve it, let me know. Thanks.
      07-25-2025, 04:35 AM   #8
gorgeto
Drives: Bmw 325d
I will let you know for sure. I need the part number i cant find it on realoem. Do you have the part number maybe? Thanks
      07-28-2025, 04:53 AM   #9
zeljko2
Croatia
32
Hello.
In the first picture sensor number 11. Part number: 13628596295).
The spacer or extension is not an OEM part but something someone made to solve the problem. I saw that for the nox sensor there is on Alibaba, but not for the particle sensor.
      09-02-2025, 12:54 AM   #10
zeljko2
Croatia
32
Does anyone have an opinion on the usefulness of spacers to move the sensor out of the main exhaust gas flow?
      09-15-2025, 12:46 PM   #11
harjap2912
Drives: 2019 G05 BMW X5 M Sport 30D Xd
currently having the same problem as described above, 2018 bmw x1 sdrive 2.0 diesel 18d, if someone could let me know how they proceeded and what they did to fix, i would appreciate that a lot, thanks
      04-20-2026, 07:38 AM   #12
peca89
24
Drives: F31 330i, F48 20dX
2018 F31 330i  [0.00]
2018 F48 X1 20dX  [0.00]
I had the same 2BA100 code appear on my 2018 20dX B47 (model code JJ11). When I read error codes using ISTA the other day, it showed that the fault is not currently present, so I successfully cleared it. After a week, the check engine light turned on again with the same error - again not currently present at the time of ISTA diagnosis.
The car was indeed driven only short distances for the last month during which it made around 200km. But before that, I was on a 3000km motorway-only trip where the car had a plenty of chance to regen. And indeed, DDE shows last regen happened about 450km ago. Therefore, I assume a forced regen now won't do any good?
Does anybody have experience with cleaning the sensor probe? Maybe that can be the issue since the error comes up only intermittently?
Finally, I can't find the original part number on realoem anymore. For my model specifically, realoem shows a generic part number and instructs me to look for appropriate part number in ISTA ?!
https://www.realoem.com/bmw/enUS/sho...diagId=13_1960
Now realoem shows that above mentioned 13628596295 is compatible only with a handful of F48 variants.
Retrofits done: 302, 319, 5AC, 5AG, 488, 5DF, 5DL, 5DP, 6NR, 6CP, 8TH
