F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F34 3-Series GT (Gran Turismo) Forum > B47 noise/vibrations at the last second of shut down
Extreme Powerhouse
      02-29-2024, 12:22 PM   #1
fliyer
fliyer's Avatar
Germany
Drives: BMW F34
Hello,
My B47 suddenly makes strange noises just before it comes to a standstill. I recorded this once and can't identify the source, maybe someone already had it.
It can be heard in the last seconds 7-8, a knocking shaking noise.
They only does that when the engine is warm. It doesn't do this when it's cold. He always used to go out with a gentle Frrrrr
recording
New Intake manifold original BMW February 15, 2024
New engine mounts original BMW 12.2023
No vaults present in IST*
3ér GT F34 (190PS), Motor: B47, Automatik, Bj. 07/2015, km: 207.000
      03-06-2024, 10:59 AM   #2
fliyer
fliyer's Avatar
Germany
Drives: BMW F34
I have replaced all Seals in the Air System and the result was the same.
But i have find out that the nois comes only in Position " P " , if i shout down in " D " or " R ", the engine stoped perfect.
Is there a problem in the 8HP gear box?
      03-06-2024, 11:07 AM   #3
Billfitz
Billfitz's Avatar
8313
Drives: '15 328iX GT
Perhaps it doesn't do it in D or R as the transmission still loads it long enough to prevent it.
      03-06-2024, 11:43 AM   #4
fliyer
fliyer's Avatar
Germany
Drives: BMW F34
also the same in Stop&Go shout down, no noises. Only in Position P
      03-06-2024, 02:45 PM   #5
Oksamit78
Oksamit78's Avatar
295
Drives: E39, F30 & F34
fliyer
Hey, not much help, but I came across this thread seems to be talking about the same issue that you are describing:
https://www.bimmerforums.co.uk/threa...utdown.590108/
2003 E39 530i 5-Speed w/ M Spec, Saphire/Black, M54B30, Active Autowerke Performance Tune
2010 Lancer GTS 5-Speed, Black Pearl/Black, 4B12
2015 F30 335i XDrive w/ M Sport Pack, Alpine White/Black, N55B30M0
2017 F34 340i XDrive w/ M Sport Pack, Azure II /Black, B58B30M0, Dinan Stage 1
      03-06-2024, 03:22 PM   #6
Billfitz
Billfitz's Avatar
8313
FWIW I never put my car in park before shutting the engine off, I always leave it in gear and let the car put itself in park when I turn the engine off. The car doesn't mind it a bit.
      03-07-2024, 07:57 AM   #7
fliyer
fliyer's Avatar
Germany
Drives: BMW F34
Originally Posted by Oksamit78 View Post
fliyer
Yes i know, but there was no result till yet
      03-07-2024, 11:34 AM   #8
fliyer
fliyer's Avatar
Germany
Drives: BMW F34
So, I just had the car on stage and it was always turned on and off, the gearbox swings back and forth quite a bit when turning it off/on. The noise comes from the very back, near the hardy disc flange. There is no oil leak there either.
I'll change the transmission mount tomorrow and see if that helps. Visually they don't look defective, but that doesn't mean anything.
      03-08-2024, 11:30 PM   #9
fliyer
fliyer's Avatar
Germany
Drives: BMW F34
It's unbelievable what I've just discovered. The wrong transmission mounts are installed in the vehicle.
In my pictures you can see that the 6875904 are installed, these are actually for a petrol engine and are much softer than those for the diesel.
The correct number would be 6796617, this was never changed by BMW. I think in the past the bearings were replaced and incorrect ones were installed. These move a whopping 8mm more under max. load. Both are visually the same, but have a different rubber mixture.
Well, I'm excited about the change.
Here again is my storage of what I need:
I had to delete the link again, the page then goes to Leebmann's unfiltered page with all the locations there are.
But all the BMW dealers in North Rhine-Westphalia I called always said "not available at the moment" until the end of March. Great, I would have liked to pick up the stock from my dealer for €24. So now Leebmann has to wait.
Here is proof again that it is wrong that 6875904 was NEVER installed in the F34. I left the engines hidden in the picture, but believe me, there are no diesel engines.
      03-13-2024, 11:07 AM   #10
fliyer
fliyer's Avatar
Germany
Drives: BMW F34
the parts are OK , i have take a look onto the drawing, 4 part numbers are printed in the rubber.
today i have change the mounts but nothing has change
      03-21-2024, 10:38 PM   #11
fliyer
fliyer's Avatar
Germany
Drives: BMW F34
I have called ZF and they think, that the parking brake hase some issues.
Next week i will visit ZF in Dortmund Germany
f30post
