02-27-2024, 04:14 PM | #1 |
25
Rep 110
Difference Coming from F30 N55 EWG to E90 N55?
I was considering going from a F30 N55 EWG to a E90 N55 and I was wondering what others think. Not considering N54 at all, since this will be my daily and don't want to get something unreliable
I am currently on BM3 Stage 2 FBO on my F30, and probably around 370~ whp? If I go FBO on the E90 N55, what numbers am I looking at? I know the E90's have a hydraulic power steering and feel much different from the F30. This is definitely a plus But in terms of reliability, is the N55 E90 less reliable? or is it only a little bit less reliable compared to the f30. What problems should I be expecting? |
03-04-2024, 06:26 PM | #3 | |
25
Rep 110
https://f30.bimmerpost.com/forums/sh....php?t=2073763 If dealership/me can't figure out this battery drain issue I was considering a e90 Power wise I was wondering the difference. Still not sure on the e90 but just considering it |
03-05-2024, 07:18 AM | #4 |
237
Rep 490
I just don't see why you would do this; a battery drain is not an issue you sell a whole car over.
Performance Mods: Eibach Pro Kit Springs, Eibach Sway Bars, KONI SA Dampers, M Perf Rear Brakes, Dinan Free Flow Exhaust, MHD Stage 2
Retrofit: Reversing Camera, Rear PDC, Front PDC, NBT Evo |
03-05-2024, 07:53 PM | #5 | |
25
Rep 110
I took it to 2 reputable indy shops and they could not find anything. Went to an actual dealership and everything seemed fine with their test. They thought it was a obd passthrough lowjack (gps I did not have access to) so I we uninstalled that and I even uninstalled carplay or anything aftermarket on the car. So the 2nd appointment is where they thought it was the non oem battery It's not a slow battery drain, sometimes it would be 2 days in a row and it would be dead when I go to work. I would drive around 30-45 mins the night before and still be dead in the morning Last edited by SpoolinAddict; 03-06-2024 at 07:16 PM.. |
03-06-2024, 07:26 AM | #6 | |
237
Rep 490
03-07-2024, 09:19 AM | #7 | |
201
Rep 545
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 So far, I spent around $1,100 on troubleshooting and the IBS negative battery cable. |
