N52 hose part number??
02-12-2024, 01:06 PM | #1 |
13
Rep 5
Can’t find it anywhere but anyone know what this hose is called?
It’s on an N52 its leaking need to figure out why and what the part number is if possible. Thanks! |
02-12-2024, 01:21 PM | #2 |
130
Rep 245
That's your Eccentric Shaft Sensor, not a hose. Common leak point.
Requires the valve cover removal to replace. https://www.e90post.com/forums/showthread.php?t=697252 |
LinnaChuk13.00 |
02-12-2024, 11:08 PM | #4 |
Art Collector
2427
Rep 3,450
Just to add: if it’s ONLY the gasket that’s leaking, it can be replaced without removing the valve cover. But the sensors do commonly fail and become contaminated with oil, after which point oil seeps out through the connector.
A good way to gauge whether it’s worth replacing the gasket (rather than the whole sensor and the gasket) is to unplug the connector and check if it’s dry. If you see any oil inside, she’s probably toast. If there’s no oil, then a simple gasket replacement might do the trick.
When I'm dead, just throw me in the trash.
02-13-2024, 07:28 AM | #6 | |
2757
Rep 1,567
But Im pretty sure I did not remove it. |
LinnaChuk13.00 |
02-13-2024, 10:02 AM | #7 | |
4966
Rep 3,035
Drives: 2006 BMW 330i MT
Garage List 2006 BMW 330i [8.21]
2009 BMW 328i Touri ... [7.90] 2013 BMW X5 35i [7.63] 2011 BMW 528i [8.75] 2006 Mazda3 [5.50] |
