BMW X1 (F48) and X2 (F39) Forums General BMW X1 Forum (F48) 【F48 X1 Suspension + Brake Kit. High performance duo】
      01-29-2024, 03:18 AM   #1
iCARMIX
iCARMIX's Avatar
Hong Kong
167
Drives: BMW
BMW X1 is a popular family car in Hong Kong. Its compact SUV size makes it ideal for navigating the narrow roads here. However, many owners, like the one in the picture, feel that the suspension and braking performance of their vehicles are lackluster, resulting in a less-than-impressive driving experience. If you want to enhance the comfort and handling of your vehicle, as well as improve its braking performance, check out this upgrade solution. The owner opted for a genuine M Performance brake kit and an ST XA adjustable suspension system.
The brake kit features 4-piston front calipers and a 1-piston rear caliper in a opposed configuration. Paired with larger 360mm front and 330mm rear brake discs, this setup provides stronger braking power and shorter braking distances but it's also eye candy, with its iconic red calipers. It undoubtedly gives your vehicle a sporty and personalized touch!
As for the ST XA suspension system designed specifically for the F48 X1, it offers superior road shock absorption compared to stock. Not only can you adjust the ride height individually from 35-55mm lower at the front and 30-50mm lower at the rear, but you can also fine-tune the rebound pressure with its 16-stage adjustment. With professional installation and tuning, you can achieve a more comfortable suspension setting or dial it up for a firmer, more responsive feel, tailored to your driving habits and preferences.
So, if you're looking to upgrade your BMW X1, consider getting this combo. Enjoy improved comfort, enhanced handling, and the ability to fine-tune your ride to suit your needs.
Here's more info on the brake kit:
https://icarmix.com/product/genuine-...9-x2-f60-mini/
And the ST XA suspension:
https://icarmix.com/product/kw-st-xa...-mini-f54-f60/
And here's everything so far:
Tags
f48 x1, hong kong, icarmix, m performance brake, st suspension
