      02-25-2008, 11:43 AM   #1
Gary@TireRack
Moderator
Gary@TireRack's Avatar
369
Drives: Formerly 1995 M3
Weights for stock wheels and tires.
Bridgestone RE050A RFT tires are standard on the 135i.
The 215/40/18 front tire weighs 23.8lbs.
The 245/35/18 rear weighs 26.0lbs.
Per member TP 135i the weights on the 264's are below.
Front wheels are 11kg (24.2 lbs)
Rear and 11.92kg (26.2 lbs)
http://www.1addicts.com/forums/showthread.php?t=4632
Stock wheels and tires together:
48.0lbs each on the front
52.2lbs each on the rear.
Gary. Tire and Wheel Forum Moderator. Tire Rack Sales Rep Gary@Tirerack.com
http://www.tirerack.com/a.jsp?a=AH8&url=index.jsp
Please refer to 'Gary/E90 Post' as your previous contact when you order online to help support this forum.
      02-25-2008, 11:51 AM   #2
mikeo
Santa Fe Concorso
mikeo's Avatar
103
Drives: '11 M-sport 328i, '13 X1 28i
Thanks, Gill.
Santa Fe Concorso - The Southwest's Premier Automotive Gathering.
      03-04-2008, 08:54 PM   #3
mjovic
45
Drives: 135i
So what does say a Michelin Pilot Sport PS2 in the same size weigh? How much weight can be saved by losing the run craps?
      03-05-2008, 12:28 PM   #4
Impulse
BMW ONE
Impulse's Avatar
15
Drives: 93 RX-7 R1, 135i
Go to the individual's tire specs on tire rack.com they will list the tire weights.
135i - Alpine White - Black Leatherette - 6-Speed - Sport Package - Aluminum trim - 6FL
      03-11-2008, 11:01 PM   #5
JAMS 135
Drives:
Just weighed my new 261M wheels, (mounted with 225s, 255s and TPMS).
Front: 52 lbs. Rear 54 lbs.
      03-11-2008, 11:02 PM   #6
JAMS 135
Drives:
Sorry, I should have stated that the tires are Bridgestone RE760s.
      03-11-2008, 11:03 PM   #7
JAMS 135
Drives:
Non RF.
      03-11-2008, 11:15 PM   #8
JAMS 135
Drives:
Inflated to 44 psi front/ 48 psi rear.
      03-11-2008, 11:16 PM   #9
Impulse
BMW ONE
Impulse's Avatar
15
lets us know how you like the tires seems like a good choice
      03-12-2008, 02:19 AM   #10
MVF4Rrider
PCA, BMWCCA
MVF4Rrider's Avatar
102
Drives: 997S, MV Agusta F4, E46 M3
Leads me to believe perhaps the wheel weights for the 264s posted in the first post are inaccurate. Seems the 261s should weigh roughly the same if not lower, and the conventional tires for sure weigh less than the OEM runflats.
'08 Carrera S 6MT Guards Red/Black ext leather, Carbon fiber pkg, sport exh, sport chrono +, PASM, Nav, Bose, 19" forged turbos, red tranny tunnel
'07 MV Agusta F4 1000 R 1+1, Corse Red/Silver, RG3 race pipes and factory race ECU
      03-12-2008, 02:27 AM   #11
turbomg
Acquiring the taste.
Drives:
Air weighs a lot.
So do edit buttons.
Edit: thanks for the info
      03-12-2008, 07:11 AM   #12
TP 135i
TP 135i's Avatar
28
Drives: 2008 135i SGM MT
FYI
The wheel weights I posted earlier are from this site http://felgenkatalog.auto-treff.com/
261s = 11.8 / 11.23 kg (18 x 7 f / 18 x 8.5 r)
264s = 11.0 / 11.92 kg (18 x 7.5 f / 18 x 8.5 r)
I don't know why the 261s are listed for 7" wide fronts. And now that I look at the numbers they don't make much sense do they?
JAMS 135 Did you weigh the stock wheels / tires before the switch ???????
2008 135i SGM
      03-12-2008, 07:22 AM   #13
larryn
2146
Non RF.
Very nice looking setup! Even with going to a larger tire, you'll shave a few pounds of unsprung weight off of each corner by getting rid of the runflats... I can't wait to see the subtle difference in the larger tires in the wheel well.
Please take some before and after pics!
      03-12-2008, 07:25 AM   #14
larryn
2146
Originally Posted by TP 135i View Post
FYI
I agree that those numbers don't make sense.
Jams doesn't even have his car yet.. just like the rest of us in the States.
      03-12-2008, 07:41 AM   #15
TP 135i
TP 135i's Avatar
28
DOH !! My bad
Well hopefully he will weigh them when he gets his car.
I feel so dumb now...
2008 135i SGM
      03-12-2008, 07:59 AM   #16
MVF4Rrider
PCA, BMWCCA
MVF4Rrider's Avatar
102
FYI
In the case the above weights are correct, there's absolutely no reason to swap 264s for 261s unless you could do it free of charge. There's no appreciable difference to offset the cost. In fact, the only reason to seek aftermarket other than to save measureable weight is to shed the tiny 7.5" fronts.
      03-12-2008, 09:13 AM   #17
Gary@TireRack
Moderator
369
Not everyone is out for weight savings. If he likes the look of the 261 better, it's a great reason to switch.
      03-12-2008, 09:27 AM   #18
MVF4Rrider
PCA, BMWCCA
MVF4Rrider's Avatar
102
Yes of course and these things are personal choices. Unfortunately BMW NA gouges you in the process. Seems you should be able to order the car with any OEM wheel BMW approves fitment.
      03-12-2008, 09:55 AM   #19
TP 135i
TP 135i's Avatar
28
I'm actually considering (haven't made up my mind yet) swapping out the stock 264s for the 261s. And this is purely for cosmetic reasons. I just love the 261s. Now after the swap I'll attempt to reclaim maybe 50% to 75% of the cost by selling the 264s to someone that would like that upgrade.
Now, having said that, I also want to wait a while and see what becomes available in the aftermarket wheel selection which would give me a different look and save weight in the process.
To be continued...
GIL.............you are listening, right?????
2008 135i SGM
      03-12-2008, 01:21 PM   #20
JAMS 135
Drives:
Thanks for the "edit" button tip, Turbomg... I learn something every day.
It's mostly emotional for me. I like the look of the 261s better and the car will look the way it does most everywhere else in the world, when equipped with the sport package. Besides, I hate RF tires.. my MCS was transformed when I switched to NRF RE050A tires.
Having said that, I will definitely weigh the stock wheels when they come
off... if there is a weight advantage to my setup; all the better.
As far as the stock wheels and tires, maybe someone will want a deal, otherwise, I will store them until I move on to something else and put them back on then.
      11-01-2008, 07:10 AM   #21
cuizhuoyi01
EVO
Drives:
I think 261 front is 7.5 not 7.
135 EVO
      08-15-2013, 12:43 PM   #22
02rsxpilot
02rsxpilot's Avatar
47
Drives: 2012 BMW 135i
2012 BMW 135i  [10.00]
2013 Mini Cooper S  [0.00]
2002 Acura RSX  [0.00]
Best thread I could find, even if it's 5 years old. So by math, from TireRack:
261M wheels--Front 52 lbs - 26 lbs 225/40/18 RE760s = 26 lbs. Rear 54 lbs - 26 lbs 245/35/18 RE760s = 28 lbs.
Oddly enough, TireRack says the current Dunlop RFTs are 24 lbs. 215/40/18 and 27 lbs. 245/35/18 (stock specs). I thought RFTs would weigh more.
This means stock setup for MSport package folks with 261M wheels is 50 lbs in front, 55 lbs in rear, total wheels + tires.
Search this Thread:
Advanced Search
1addicts
