01-08-2024, 05:56 AM | #1 |
Rep 4
Read TPMS/RDC live data from ECU
Hi,
Is anyone aware of a way to retrieve live data from TPMS unit on BMW F series vehicles? Specifically, I'm interested in whether anyone knows how to obtain the IDs of paired sensors. In ISTA+, I haven't found an option to read data from the specific ECU. Bimmerlink/Bimmercode also yielded no results. I only have E-sys in a VM without EST, so I can't read CAFD. Does anyone know where to look? Thanks a lot! |
01-08-2024, 11:14 AM | #3 |
Rep 4
Yes, I was able to code RDC temperature iDrive on my F36, but this only gives me pressure and temperature.
I would like to know RDC sensor IDs. Perhaps a kind individual could check if these values are accessible through e-sys. |
01-14-2024, 04:35 PM | #5 |
Rep 4
With ISTA+ I got lucky with G21, there is procedure for reading stored sensor values.
With F56 it is not available (only sensor programming as seen on the screenshot). I would try later with F82. I don't have Tool32 utility. I was browsing options using Deep OBD, but I couldn't find any related live data for F56/F82 ... |
01-14-2024, 10:24 PM | #6 |
580
Rep 2,047
Deep ODB should also work since it uses the same prg as to read the modules. You just have to know the correct prg and parameters to query.
Tool32 is part of the bmw standard tools |
