01-27-2008, 01:36 PM | #1 |
4449
Rep 7,594
Drives: '19 M2C
Xenon Color Shift?
Anyone know if the colorshift time frame on the xenon is still 150-200hrs?
www.ReTuneTheDeTune.com
2019 M2 Competition (Sunset Orange) |
02-06-2008, 06:23 PM | #3 |
123
Rep 2,295
That depends on the bulb. If its the Philips 5k then yes, they will.
If they are the Osram/Philips 4300k, no. But the Philips 4300k will had more of a purple/blue tint over time... |
02-07-2008, 07:25 AM | #4 |
4449
Rep 7,594
Drives: '19 M2C
No, I am not talking about the warm up after ignition. All xenon bulbs start out a tad yellow until they basically break-in. Then the 4100k Philips/Osram OEM HID D2S turn white.
---- Actually Kris the OEM bulbs are not 4300k like the kits, they are 4100k (4100 k Philips/Osram OEM HID D2S). Here is an OEM DENSO ballast and 4100k OEM bulb kit I had. You can see the bulbs brand new, then the color shift after 100+ hrs.
02-07-2008, 07:39 AM | #6 |
4449
Rep 7,594
Drives: '19 M2C
02-07-2008, 03:28 PM | #8 | |
123
Rep 2,295
As I mentioned, some of the BMW's come with OEM 5k bulbs, 85122+ they are labelled as. These color shift after about 100hrs. The picture you've shown is a D2R bulb, I dont think any of the new BMW's have D2R reflector based bulbs. They are all D2S |
02-07-2008, 04:54 PM | #9 |
4449
Rep 7,594
Drives: '19 M2C
Philips/Osram doesn't make a 4300k bulb for the US market. 4100k is the only temp bulb legal in the US. That may explain your bulbs in Australia.
D2R are only for reflector housings, no BMW with projectors have ever used them. They us D2S which are for projector housing. The only difference between the bulbs is a coating on the D2R to reduce glare. The bulbs I show are D2R with the coating removed, now it's a D2S.
02-07-2008, 04:59 PM | #10 |
4449
Rep 7,594
Drives: '19 M2C
OEM Specs:
Philips D2S burner specs: Lamp Power = 35W Lamp Current = 0.45A Base = P32D-2 Luminous Flux = 3200lm Color Temprature = 4100K Rated Life = 3000 hours Overall Length = 77.5mm
02-14-2008, 10:25 PM | #11 |
Commander
Rep 320
whats the factory high beam bulb number?
FS: CT9A parts and Enkei Wheels!!! PST
BLUEFAKES.COM ARE SCAMMERS, LIERS, AND CHEATERS! DO NOT BUY FROM THEM!!! |
