11-27-2023, 03:47 PM | #1 |
Rep 3
E-SYS flashing NBT error
Hi, bimmer fam!
Today, I tried to flash NBT (ID5->ID6) to the latest one and got stuck. The bootloader successfully uploaded. At around ~20%, errors started to come up. At this point, NBT shows a blue screen with Flashing time: 00:00:00. I would greatly appreciate any suggestions. Setup: CTEK MXS 5.0 Battery Charger MacBook Pro (Intel) running Parallels with Win11 (64) E-Sys 3.40.1 (64bit) v4.44.20_PSdZData followed this manual: https://drive.google.com/file/d/1yqT...Lgkahfy2I/view Log: HTML Code:
<[HU_NBT2 - 63 - swfl_0000271f-007_049_001] Transaction type: swDeploy; Message: 19% progress on ECUId:HU_NBT2_0x63 [100% of swfl_0000271f-007_049_001] [TRANSACTION]> <[HU_NBT2 - 63 - swfl_0000271f-007_049_001] Transaction type: swDeploy; Message: 19% progress on ECUId:HU_NBT2_0x63 [100% of swfl_0000271f-007_049_001] [TRANSACTION]> <[HU_NBT2 - 63 - swfl_0000271f-007_049_001] Transaction type: swDeploy; Message: 19% progress on ECUId:HU_NBT2_0x63 [100% of swfl_0000271f-007_049_001] [TRANSACTION]> <MCDDiagService<id=332900, job=com.bmw.psdz.jobs.http.MCD3_PerformECUFlash_Http, service=RC_CHECK_MEMORY_HTTP - RoutineControl CheckMemoryHttp, description=error: timeout, link=HU_NBT2_63_ETHERNET_63> [DIAGSERVICE]> <MCDDiagService<id=333200, job=com.bmw.psdz.jobs.http.MCD3_PerformECUFlash_Http, service=RC_CHECK_MEMORY_HTTP - RoutineControl CheckMemoryHttp, description=error: positive response with negative content, link=HU_NBT2_63_ETHERNET_63> [DIAGSERVICE]> <[HU_NBT2 - 63 - swfl_0000271f-007_049_001] Transaction type: swDeploy; Message: 19% progress on ECUId:HU_NBT2_0x63 [100% of swfl_0000271f-007_049_001] [TRANSACTION]> <[] job failed with negative response error: code: result of the routine control service is not correct description: service RoutineControl CheckMemoryHttp returned unexpected result: debugInformation_02_FF; LinkName: HU_NBT2_63_ETHERNET_63 severity: FATAL ERROR [THROWABLE]> <[HU_NBT2 - 63 - swfl_0000271f-007_049_001] Transaction type: swDeploy; Message: TA finished [TRANSACTION]> <[HU_NBT2 - 63] There was an error during TAL execution, please check the log files. [WARN]> <[HU_NBT2 - 63] - [Exception - HU_NBT2 - 63] job failed with negative response error: code: result of the routine control service is not correct description: service RoutineControl CheckMemoryHttp returned unexpected result: debugInformation_02_FF; LinkName: HU_NBT2_63_ETHERNET_63 severity: FATAL ERROR > <[HU_NBT2 - 63] finalizeECUFlash started [PROGRESS]> <[HU_NBT2 - 63] finalizeECUFlash finished [PROGRESS]> <[] There was an error, please check the log files. [WARN]> <[] - [Exception - HU_NBT2 - 63] job failed with negative response error: code: result of the routine control service is not correct description: service RoutineControl CheckMemoryHttp returned unexpected result: debugInformation_02_FF; LinkName: HU_NBT2_63_ETHERNET_63 severity: FATAL ERROR > <[] finalizeVehicleFlash started [PROGRESS]> <[] finalizeVehicleFlash finished [PROGRESS]> <[] prepareVehicleForCoding started [PROGRESS]> <[] prepareVehicleForCoding finished [PROGRESS]> <[] finalizeVehicleCoding started [PROGRESS]> <[] finalizeVehicleCoding finished [PROGRESS]> <[] finalizeTALExecution started [PROGRESS]> <[] finalizeTALExecution finished [PROGRESS]> <TAL execution finished [TAL_EXECUTION_FINISHED]> TAL-Execution finished with status: "FinishedWithError". TAL execution finished. Duration: "17min 46s". <> Last edited by MrBombastic; 11-27-2023 at 03:57 PM.. |
11-28-2023, 01:00 PM | #3 |
Rep 3
11-28-2023, 01:04 PM | #4 |
Rep 3
UPD: Error fixed. I just did a successful flash.
According to the log, issues come with HTTP transferring. Steps that I did to avoid errors: -Disable all internet connections on MBP -Enable bridge-only network access in Parallels -Run local DHCP -Static IP It might be helpful for somebody in the future. |
12-03-2023, 02:55 PM | #6 |
23
Rep 97
