08-27-2023, 08:07 PM | #1 |
19
Rep 86
Drives: 2023 BMW M3
BMW Tech Overfilled My Oil
Did my first oil change post break-in yesterday @5500 miles and noticed that a a little over 8qt of oil came out of the pan. I've heard from some reliable sources that the M3 calls for 6.5liters (6.87qt) while others say a oil service calls for 7liters (7.4qt). So BMW tech overfilled by .6qt on the low up to 1.13qt on the high end. I ended up adding 6qt of oil, did a oil measurement and iDrive told me that oil level was OK and the virtual dipstick was more than 3/4 of the way to the max level.
This is probably me letting my paranoia get to me...but would driving 4K+ miles with an engine that's been overfilled cause any long term issue? I've heard that overfilling an engine can cause significant damage but those cases is when it was over filled by a lot more than 1qt right? |
08-27-2023, 10:45 PM | #2 |
3274
Rep 6,723
Service is 7 liters.
Slight overfill is ok but 1 liter could be on the border of a tad too much. Unfortunately you did the change on your own and may not have much recourse. The flip side is that even if the dealer did your oils change, they would never know either because they do a bulk drain and to my knowledge, do not measure discharge. I think these have oil overfill warnings? |
08-27-2023, 11:01 PM | #3 | |
19
Rep 86
Drives: 2023 BMW M3
08-27-2023, 11:06 PM | #5 |
19
Rep 86
Drives: 2023 BMW M3
08-27-2023, 11:09 PM | #6 |
2217
Rep 2,022
The picture you posted after the oil change. Ur iDrive measurement is below Max which is probably fine. I looked on mine it’s recently it was right at Max. Sounds like you put recommended amount. Maybe they put more at the dealer ? Cuz like I said mine reads at Max. Not sure….
08-27-2023, 11:16 PM | #7 | |
19
Rep 86
Drives: 2023 BMW M3
kgelfen3602217.00 |
09-19-2023, 03:53 PM | #9 |
Racecar Driver
1289
Rep 1,955
Drives: BMW M4
Back when I used to be a Technician for Toyota, we were told to ensure the dip stick was to max before letting the car leave. Even though the manual would say to add like 5.3 QTs, the oil wouldn't reach the max line and customers came back complaining that we scammed them and didn't fill the oil to the max line.
So we were instructed to do the following: 1) Add Oil to Specifications. 2) Turn On Car and let it run for a few seconds. Check for leaks. 3) Power off car - Check Dip Stick. 4) Top off oil to ensure oil reads to max line. 5) Turn on car and let it run for a few seconds. 6) Power off car - Check Dip Stick Again So I have a feeling the dealership you went to probably got the same "scolding" I got in the past because of a customer complaint (s).
N1rve
2019 BMW ///M4 - Alpine White | Sakhir Orange/Black Leather | M-DCT | Executive Package | 19" Black 437M Wheels | Carbon Fiber Trim | Sunroof | Active Blind Spot | Heated Steering Wheel | Adaptive M Suspension |
09-20-2023, 11:48 AM | #10 |
In the Details
1810
Rep 867
Drives: Yes
Garage List 2020 AMG GTR [0.00]
2022 R8 Quattro Spyder [0.00] 2023 X5M50 [0.00] 2023 718 Spyder [0.00] 2024 Silverado [0.00] 2024 Civic Type R [0.00] |
mathys202.50 |
09-20-2023, 01:37 PM | #11 |
2885
Rep 2,616
Drives: 2024 M4 Convertible
I think you're putting too little faith in the technology. There's a reason why liquid level sensors are cheap. They're so robust and dated that a failure is both 1) so incredibly unlikely that you'll win the lottery if it happens to you easily and 2) easy to detect with a failure warning.
