BMW M3 and M4 - The Icons
home
Classifieds Sponsors Classifieds Suspension / Brakes / Chassis / Spacers
      07-31-2023, 12:24 PM   #1
IND-Distribution
BimmerPost Supporting Vendor
IND-Distribution's Avatar
9587
Drives: G82 M4 / G87 M2
IND | Ohlins G8X M3 / M4 Road & Track Coilover Kit
Öhlins Road & Track suspension systems are engineered to provide the ideal balance of track capability and street comfort. We have utilized over 40 years of experience in the motorsport and OE industries to produce a package that incorporates patented technology with OE levels of quality and longevity. Our tuning philosophy is applied to each particular application to extract the most performance while still maintaining ride quality.
One way Öhlins achieves this balance is our patented Dual Flow Valve. The DFV provides an additional oil bypass when bumps get severe. Engineers can tune the damper for increased support when turning and braking while maintaining composure over track curbing and rough pavement. This technology allows the use of linear spring rates (just like a motorsport application) for further chassis support without affecting daily comfort.
Another feature is the damping adjustability via a single “clicker” knob that proportionally increases compression and rebound damping to best suit the driver’s needs. Whether it’s a smooth track or a weekly commute, the dampers can be adjusted within their usable range to best suit track or street conditions. In other words, an engineering degree isn’t necessary each time an adjustment is necessary.
The BMW G8X front shocks utilize monotube DFV struts with separate spring preload and height adjustment. For the rear, inverted, aluminum DFV shocks come with height adjustable spring perches. Separating spring preload from height adjustment allows precise height adjustment without affecting suspension travel. Considering the G8X M Cars are already tuned as a high performance street cars with track capability, Öhlins took the approach most drivers will utilize track-oriented tires and tailored the suspension to match. The tuning approach minimizes understeer without the necessity of aggressive alignment settings or wide front tire fitments, while still maintaining safety and comfort on the street.
Product Details:
  • Patented Dual Flow Valve
  • Height Adjustable
  • 20 Clicks of Adjustable Damping
  • Monotube Design
  • Rebuildable
  • Optional EDC Cancellation Kit
  • Two Year Warranty
The Ohlins G8X M3 / M4 Road & Track Coilover Kit may be viewed at the following link to our online store:
https://ind-distribution.com/product...ion-road-track
Please contact IND by phone or email for more information or to place your order.
866.963.4520 | info@ind-distribution.com
IND DISTRIBUTION | 866-963-4520 • INSTAGRAMYOUTUBEFACEBOOKFLICKR
g80
