BMW M3 and M4 - The Icons
home
Technical Sections Mechanical Maintenance: Break-in | Oil & Fluids | Servicing | TSB | Recalls
      07-03-2023, 03:16 PM   #1
fanofbmwe46
2071
Drives: M3
Those of you who have replaced your brake pads on a G8X. Do you always replace the one time nuts with new ones? Part number 34112284399 x quantity of 4
How imparative is it to do so?
      07-03-2023, 07:48 PM   #2
forcefed
forcefed's Avatar
2567
Drives: .
I've heard of torque to yield bolts/studs... but one time use nuts? If the nut is being replaced why not the stud?
You can try to find the nut yourself, its simply a m12x1.5 flanged nut with a 10.9 grade hardness, but its hot dipped galvanized i believe so not exactly easy to find. The amount the dealer wants for this is.... nuts.
I reused mine.
      07-03-2023, 07:52 PM   #3
chris3g
1569
Drives: 2023 M3 xdrive
According to the offical procedures per BMW TIS, nearly every bolt and nut torqued to more than 10nm on the entire car is marked as “renew”. Took your exhaust brace off? That will be 6 new bolts, per BMW. It’s a bit ridiculous really.
Appreciate 2
forcefed2567.00
LuckyBrand1317.00
      07-03-2023, 08:26 PM   #4
fanofbmwe46
2071
Drives: M3
What’s the worse that could happen.. caliper falls off? That would of course be catastrophic.. but what are those chances? If torqued correctly and inspected every so often is that sufficient enough?
      07-03-2023, 09:07 PM   #5
forcefed
forcefed's Avatar
2567
Drives: .
It actually can't fall off because to take it off you pull it off to the side and it needs to clear the rotors... thankfully the wheels will block it from ever doing that
      07-04-2023, 07:25 AM   #6
vbb
vbb's Avatar
1864
Drives: 2022 M4 manual
I did not. I just retorqued everything down to spec and got on with it. Same with the exhaust brace when I replaced my midpipe.
Previous notables:
'05 S2000 | '07 335i | '09 ISF | '08 911 Turbo | '09 911 C2 | '15 Cayman | '15 RCF | '17 MX-5 RF | '17 C7 Corvette
      07-04-2023, 07:49 PM   #7
Jon H
392
Drives: 2015 911 GT3
Reused and immediately had a track day. No issues.
M3Cx, E92 M3 6MT
Previous cars: '21 Supra, '17 GT-R, '15 GT3, '13 GT-R '09 GT-R, '06 Z06, '06 Evo MR, '05 M3, '03 Evo, '00 Miata.
      07-05-2023, 07:56 AM   #8
beamlord
431
Drives: 2023 m3c
I did a brake pads change at the dealer and they didn't replace the nuts. Obviously they are following the TIS, so I guess even the BMW mechanics don't believe this is necessary.
AND1_M369.00
      07-31-2023, 07:17 PM   #9
LuckyBrand
LuckyBrand's Avatar
1317
Drives: BMW X5 F15, G05 X5, G80 M3 6sp
I didn't replace mine. No issues.
g80
