Tire Pressure Monitoring Systems (TPMS)
01-21-2009, 02:22 PM | #1 |
M3Post Supporting Vendor
87
Rep 964
This is probably old news to most of you, but here is the latest TPMS information from our tech team:
Tire pressure monitoring systems (TPMS) are now impossible to run from when buying a new vehicle. Every new vehicle made for sale in the USA has a TPM system as standard equipment. There are several exceptions though: the vehicle must have only four wheels (so dual-wheeled trucks or motorcycles are exempt), and the GVWR must be less than 10,000lbs. We carry all sensors and valves for every model of BMW and Mini up to the current model year. The older model BMW’s and Mini’s that have an indirect system do not need TPMS valve sensors. The basics of the direct TPMS is that it uses a sensor in the wheel/tire to wirelessly relay pressure back to the driver on some sort of display. Some vehicles have a digital info screen that will show all four tire pressures (five pressures if spare has sensor) all the time. While others might just flash a low-tire-pressure light on the dash. There are also two different styles of sensors for this system: a valve sensor and a strap/band sensor. Only valve sensors are used by the direct system-equipped BMWs, although if you bought an aftermarket SmarTire TPM system, those use the sensors held on by a strap around the barrel of the wheel. BMW’s indirect system, usually used on older model years and also in many models in Canada, will not affect the choice of switching aftermarket wheels or tires. The system runs off of the ABS/wheel-speed sensors which “count” the number of revolutions of each tire. If the right-front tire is low (25psi) it will spin faster than the left-front tire (35psi), so the ABS system will recognize this change and alert the driver with a flashing light near the gauge cluster and possibly a loud chime. Most new U.S. market BMWs use the valve-mounted TPMS. All BMW valve sensors are currently being produced by BERU and are sold by us in two parts: the sensor component and the metal valve. The size of the sensor shouldn’t be a problem for many wheels, but if the valve hole is in the middle of the wheel’s barrel, then obviously the sensor will not fit properly. The wheel industries are aware of the valve sensors and are rushing to get most of their wheels TPMS-compatible. If you have any questions about the TPMS-fitment on a wheel that The Tire Rack sells, I can look up the wheel and confirm if it will work with your vehicle.
_______________________________________________
I have accepted a new position at Tire Rack and am no longer in the sales department. gary@tirerack.com is available to assist with M3 questions. Last edited by ben@tirerack; 11-05-2010 at 04:58 PM.. Reason: possible confusion regarding direct vs indirect systems |
01-21-2009, 02:52 PM | #2 |
///M Fan
366
Rep 2,159
Drives: '09 E92 M3 IB/'17 f85 X5M LBB
Thank you, that is really good to know...
'09 E92 ///M3 Interlagos Blue,6MT,Silver Novillo Leather,CF Trim,Premium Package,Technology Package,Cold Weather Package,Premium Sound,19"Wheels,Moonroof-Toy/'17 X5M, Long Beach Blue, Executive Package,Technology Package, Lighting Package, Driver Assist, Full Mughello Red Interior, 21" wheels-Toy/'14 535i with M Sport and 19" wheels-Daily
01-21-2009, 03:14 PM | #3 |
26
Rep 365
mine keeps saying its low when it gets colder but when i check its 35 all around. i guess my gauge could be off but it's consistent every time i check, which i stopped doing after 3 normal readings
01-22-2009, 09:05 AM | #5 |
87
Rep 964
Current cost of the set of sensors (as of January 22, 2009) is $200 + shipping. Shippng will be approximately $9 anywhere in the continental U.S.
I have accepted a new position at Tire Rack and am no longer in the sales department. gary@tirerack.com is available to assist with M3 questions. |
01-22-2009, 09:29 AM | #6 | |
87
Rep 964
When the car sits, and the tires are cold, the pressure drops just enough (due to the lower temperature) to trigger the TPMS. You start driving, the TPMS light goes on, you keep driving for a little while, then stop and check. By then, the tires have gotten some heat in them from driving, and the pressure is back up. To test this theory, without adjusting your pressure at all, try checking the pressure on a very cold day before driving. If it comes in below 35, that is the answer. If not...then I blame crazy electronic gremlins
01-22-2009, 02:41 PM | #7 |
NASA SpecE30 Racer
82
Rep 1,307
I'm assuming the TPMS work with the Volk TE37s you sell.
King Tut
2012 BMW M3 Individual: Sold lsb.ridedomain.com 1987 BMW 325is SpecE30: spece30.ridedomain.com 2009 BMW M3 Coupe: Sold e92.ridedomain.com |
01-27-2009, 05:22 PM | #8 |
191
Rep 2,867
I just ordered from tire rack a set of oem tpms sensors. My invoice says its the 433mhz tire pressure sensor. Is this the correct ones? Just wanna make sure. Total price came out to 176.13
01-27-2009, 06:48 PM | #9 |
87
Rep 964
Yes, that is correct. They should be the Beru brand. That is BMW OEM.
01-27-2009, 06:49 PM | #10 |
87
Rep 964
Sure do
01-27-2009, 07:05 PM | #11 |
NASA SpecE30 Racer
82
Rep 1,307
How did you get that price? Did you not buy the valve stems as well? I thought you had to buy both.
King Tut
01-28-2009, 12:23 PM | #13 |
87
Rep 964
Sounds like you might be missing the valve stems. PM me with your order # and I can check.
03-21-2009, 04:40 PM | #14 |
1251
Rep 6,913
So do any aftermarket rims come WITH TPMS sensors...or are they typically just TPMS compatible? What about BBS CH?
2022 Dravit/Fiona M3cx - Dinan midpipe w/VC, NW Carbonhaus CF, AST Springs, FC Spacers...more to come!
2016 Indi F80 M3 - SMB|Amaro | Mode Carbon | ESS | Akra EVO | KW HAS...SOLD 2012 MR e92 M3 DCT, ESS SC, Brembo BBK, BBS FI... GONE but not forgotten! 2008 AW e92 M3 6MT, ESS SC, BBS LM's...SOLD! |
03-21-2009, 10:20 PM | #15 |
NASA SpecE30 Racer
82
Rep 1,307
They never come with the sensors.
King Tut
04-03-2009, 08:52 AM | #16 |
4 * General
56
Rep 644
I have a set of aftermarket wheels that are Vellano VSI can I use the tmps with them? i know the valve stem are 90 degrees inside???
Nissan GT-R (Sold) E92 M3 + 335 (sold) F10 535 (sold) When Driving Nice Whips It Helps To Have Nice Kix!
05-27-2009, 04:24 PM | #17 |
JOSH SHOKRI.
524
Rep 5,881
Drives: 991 GT3RS, 964, Raptor
I couldn't find the Beru brand, I only found Hella and Orange.
Can you supply me a link? Thanks.
Current: 16 991 GT3RS , 91 964 C2, 17 Raptor | Past: 2015 991 GT3, 2015 i3,15 YMB F80 M3, 13 E92 M3 DCT, 08 E92 M3 6MT, 07 E60 M5, 02 E46 M3
Instagram: @josh_speeddistrict #SpeedDistrict @SpeedDistrict |
05-27-2009, 04:39 PM | #18 |
56
Rep 1,164
That is funny, Beru was all I could find. Beru is who makes the OEM ones as well. You can find the Beru ones on Ebay for about $200/set, including the valve stems.
-Andy
2008 M3 Sedan- Alpine White
09-18-2009, 02:42 PM | #19 |
15
Rep 96
I just brought the new set of BBS LM with the TPMS kid for my E92 M3 for you guys. When i bring it to wheel shop, they told me the valve hole is too small, and will not fit the OEM TPMS. And i show them the TPMS kid, they told me not going to fit. Pls advice if you have the instruction for that kid?? pls help, thanks
01-01-2010, 08:17 AM | #21 |
31
Rep 385
Rod is to hold valve stem when tightening and extra washer is so you have options in washer thickness depending on wheel the kit is being installed on.
