Bimmerpost
4 Series
2019+ BMW 3 AND 4-SERIES FORUMS (G2x Generation) Local Forums USA - Southeast Purchased a used 2020 M340i
      05-27-2023, 08:21 PM   #1
pennium
Drives: 2020 M340I
I just bought a used 2020 M340I, horn and paddle shifters don't work, neither does the wireless charging pad. Tried changing fuses, still doesn't work. I suspect the car is tuned because it's ridiculously fast and came with a custom exhaust. Can someone help?
It runs great no check engines (although it could be cleared, I'll have to get it plugged in)
Can someone help? Thank you!
      12-01-2023, 08:36 AM   #2
Mposter
Mposter's Avatar
13
Drives: 2020 BMW M340i
Did you ever get this fixed?
If not the wireless charging pad has to be turned on in the iDrive. However it sucks so you are better off leaving it off.
You need to remove the steering wheel airbag and check and make sure the paddles are even plugged in and go from there.
g20
