05-27-2023, 12:48 PM | #1 |
Rep 22
Drives: BMW F32 428i 2013
my bonnet release isnt working
Hello, i removed my bonnet release leaver the other day to put a wire through to my door, and when i reattached it, it just doesnt work... no boot noise, no resistance when pulling, it wont let me add a video but it doesnt work, does anyone know whats happened? And yes i've pulled it 2 times for anyone who is gunna ask
05-30-2023, 04:47 PM | #2 |
Rep 59
Fitted incorrectly, try talking it back off, checking install and reinstall perhaps. If that doesn't work, could be due to lack of lubrication on the mechanism, ask someone to push down on the bonnet at the same time you pull the bonnet latch
06-08-2023, 10:32 PM | #3 |
55
Rep 177
More than likely the join where the two cables link from interior to the two locks may have popped out of the hole it is secured in and the entire setup is floating and adding no tension when pulled. You will have to remove the wheel and front fender shield and manually pull the cable going to the bonnet locks to release it to get inside the engine bay to address the issue.
