Manifold Vacuum Lines?
05-15-2023, 10:27 AM | #1 |
24
Rep 18
Hi, I’m new to working on my 2007 335i and have some questions about these lines going into the manifold.
I’ve pulled off the manifold and cleaned it , the throttle body and the intake valves (new gaskets for the manifold and throttle body too), I’m almost ready to put everything back together. I had ordered new vacuum hoses and bought 3.5mm silicon high temp just like is recommended everywhere I could find. Now that I’m looking at it, I’m hesitant to replace these. There is a huge difference in inside diameter between the original hoses and the ones I bought. I’ve attached pictures. Can someone please tell me what I need to do? These are vacuum lines, right? When I end up replacing the lines on the left side, will I encounter the same difference in size? Thanks! |
05-18-2023, 08:59 PM | #2 |
24
Rep 18
No one has responded to this, so I’ll post an update on what happened
It was the hose that I ordered, it wasn’t exactly 3.5mm. I had also ordered 10 feet of a baby blue hose, which turned out to fit much better! |
