05-15-2023, 09:18 AM | #1 |
64
Rep 121
creaking noise coming from rear
what is this creaking noise im hearing from my rear when i break after rolling such as in a drive thru moving up?
05-15-2023, 11:48 AM | #2 |
19
Rep 86
Drives: 2023 BMW M3
05-15-2023, 12:57 PM | #3 |
64
Rep 121
i feel like its the brakes cuz it happens after i completely stop , the creak comes from the rear almost like wood creaking. I have not had my break in yet. happens mostly when i let the car roll in drive and then completely stop. doesnt happen when im driving over 20 mph and stop, only slowly like in a dirve thru, start and stop
westsidecamper7.50 |
05-15-2023, 01:25 PM | #4 | |
19
Rep 86
Drives: 2023 BMW M3
Here's a thread of other having similar noise complaints. https://g80.bimmerpost.com/forums/sh....php?t=1819659 |
02-11-2024, 02:01 AM | #6 |
Rep 2
experiencing same creaking from rear 1-2 seconds after coming to complet stop. If anyone with same issue had there car at service and diagnosed share.
Much appreciated. |
02-12-2024, 08:23 PM | #8 |
Rep 2
To add additional description it feels like the break calipers compressing the rotors after a complete stop followed by brake pedal dropping further down during this creaking-popping noise.
03-06-2024, 04:02 PM | #11 |
Rep 12
I’m having the same issue also. Sounds like it’s from the rear, both left and right sides lasts about 3-4 seconds only after stopping slowly . Does not happen in reverse, Car is new I have less then 200mi on it
03-06-2024, 05:35 PM | #13 |
Rep 12
I’ve been pretty good with bedding in the brakes properly and all that.. what’s weird is that it only started yesterday. Drove around last Sunday with some nice weather and no issues.. I did some tests today and warmed up the brakes and then tried again, still the same weird noise. No matter if I’m applying it hard or soft, and the sound is a good 2 seconds after the car is stopped. It sounds like the old school wooden clicking crank sounds of a roller coaster. Had it added as a video attached , 2 videos merged. Pulled it into the garage for the sound because it’s raining today so don’t mind that. They are the regular brakes not ceramic. Anyone have an idea of what it could be?
https://m.youtube.com/shorts/ADwbexZ...CZ3_Tn3h6hZnCP |
03-06-2024, 05:49 PM | #14 |
1220
Rep 853
Oh, it’s after you come to a complete stop. Weird… the other poster made it seem like it’s when you riding the brakes and inching forward a bit.
The video makes it sound like it’s super chatty valves in the exhaust. Have someone shine a light into the tailpipe and see if they’re chattering after you come to a stop. If it’s not that mess with the parking brake to engage disengage it to see if it sounds similar at all. |
03-06-2024, 06:02 PM | #15 |
Rep 12
Yep did the parking brake earlier, Engaged and disengaged it couple of times, changed from sport then to efficient, Tried it from cold and then drove a bit to warm the brakes up, etc.
I had a neighbor stand next to it and listen for me and said its definitely coming from the rear wheels. I know it’s hard to tell from the video but it’s definitely not exhaust flap sounds. I have a feeling it’s a problem with the rear calipers, but not sure. I hope I can figure it out to avoid a lengthy visit to the dealer, but may have no choice |
03-06-2024, 10:32 PM | #16 |
1220
Rep 853
Does it change at all if you flip the brakes from sport to comfort and vice versa? It sounds too clunky and quick to be the calipers… they’re hydraulic… the pads don’t disengage enough to make that much of a clanking sound if they were clamping on. And the parking brake is screw servo driven, so it would again be too slow and would whine more. The valve controls are fairly close to where the back wheels are.
A while back, there was an issue on some Audis where from the factory, the valve controllers weren’t preloaded properly on the valves and would cause a rattle almost like a chatty internal wastegate flutter when it would try to partially articulate the valve. That’s kind of what it sounds like to me… I could be wrong, but it’s very metallic and clanky mental sounding to me in the video. |
03-07-2024, 09:34 AM | #17 |
Rep 12
I did some more testing to try to narrow it down. It seems like it also happens with using auto-hold, but even more so. When I brake going forward and come to a stop, the noise will happen. But If I go in reverse and come to a stop with autohold Off (no matter if gently or normal) it does Not happen. But with playing around with all settings, when I put the auto hold on, it continues to happen going forward but Also when coming to a stop after reversing.
So it’s definitely a braking issue since (I assume) the auto hold is simply the rotors being clamped down to hold electronically while in traffic, etc I added another clearer video, its the rear driver side wheel area. This is a slow forward about 8mph and coming to a stop. The sound may seem like someone is aggressively holding down the brake pedal but it’s a very gentle hold I have on it https://m.youtube.com/watch?v=xop0mp...ature=youtu.be |
03-07-2024, 03:46 PM | #18 |
1220
Rep 853
Dumb question, but is it on both sides or just the driver’s side? Since it happens on hill hold, it possible it could be the parking brake because I think that’s what’s used for that… not sure for BMW for sure, but on Audi, yes.
That said, you can probably (if you want to) reach behind the wheel to the back of the caliper where the electronic plug is for the parking brake and unplug that. If it’s not engaged, you should be able to then move the car again and see if it still does it, or not, then you’ve got your answer and it needs to be taken in for the EPB motor/servo to be replaced on the caliper. Is this car auto or manual? |
03-07-2024, 04:22 PM | #19 | |
Rep 12
Was going to do a manual adjustment but not possible. Not a dumb question at all, it sounds like it’s more on the driver side, but that could be the echo of the garage wall or just because I’m closer to it when driving.. I’ll give it a shot to disconnect and reconnect it. Do you happen to have or anyone else have the diagram of the rear brakes of where the servo is? Was going to spend the $150 for the service manual online to grab the diagram but I’ve have enough of this troubleshooting for today lol |
03-07-2024, 05:02 PM | #20 | |
Rep 12
Yep, that’s the culprit Thank you for the help , much appreciated 🫡 |
03-07-2024, 09:43 PM | #21 |
1220
Rep 853
Yeah, they can’t be drive by wire. Just the parking brake (screw within the caliper piston) is electronic. Brakes are hydraulic.
Anyway, sounds like that’s the issue. What’s probably happening is when you come to a stop, the car is trying to engage the parking brake for some wacky reason, even when hill hold isn’t on. They’ll either replace the motors or the whole caliper… most likely the whole caliper. |
03-08-2024, 11:10 AM | #22 |
17
Rep 43
