05-14-2023, 03:11 PM | #1 |
76
Rep 291
Swapping tires after winter - better ones on front or back?
About to throw my summer tires back on. I have two that are just slightly worn more than the other two. Many sites say "new" tires should go on the rear for all cars, but what about ones slightly more worn than others? I'm not planning on replacing two at a time. I want to even out the wear. I assume the fronts wear slightly more than rears?
05-14-2023, 04:29 PM | #4 |
1641
Rep 1,558
Drives: 2022 X3 M40d LCI
Some interesting and probably bedtime reading, especially as it explains the different drive modes etc. if you have a square setup it’s obviously easier and more economical.
https://www.uniroyal-tyres.com/car/t...%20a%20vehicle.
Current - 2022 X3 M40d LCI in Brooklyn Grey.
Modifications - AutoID Front Splitter. DTUK Pedalbox Plus. Gloss Black M Badges. 3d Maxpider Kuga Floor Matts & Cargo liner. BMW M-Performance Flow Through Spoiler. Mid-Trunk Spoiler. 15mm Spacers all round. AP Arch Guards. X3M Side Vents. 699M Wheels Gloss Black |
05-14-2023, 06:09 PM | #5 |
159
Rep 151
I was told to put your best tires on the front wheels, the ones that steer the car. If a bad tire fails on a rear wheel at least it will be easier to maintain control of the car than if a front tire failed.
05-14-2023, 11:02 PM | #6 | |
826
Rep 874
This is not entirely an issue on dry roads though. |
05-14-2023, 11:13 PM | #7 | |
159
Rep 151
"Rear-tire blowouts are usually more disruptive and dangerous than front-tire blowouts, as drivers have no control over the rear end of the vehicle. Front-tire blowouts are still dangerous but generally easier to manage, as you should be able to steer to counteract the force of the blowout." Who am I to argue with Google. |
05-14-2023, 11:20 PM | #8 | |
826
Rep 874
05-15-2023, 12:09 AM | #9 |
83
Rep 261
Rotate regularly. Not possible in my garage, where they store my winter/summer tyres. That's why I want a jack to correct it in case I'm not happy with tyre wear. X3 has rear wheel preference. Better tread to the rear IMO.
05-15-2023, 06:51 AM | #10 |
64
Rep 73
First off, I assume you don't have staggered sizes. If you do, then this isn't even a question.
If all 4 are the same size, none of them are close to worn out, and your goal is to even out wear, put the better tires on the rear. Every rear-drive or rear-biased car I have had has worn its rear tires significantly faster than the fronts |
