05-01-2023, 03:31 PM | #1 |
25
Rep 34
acoustic glass
Hi all!
Does anyone have ny experience with the acoustic glass option (for passenger and driver sides)? Does it only reduce the wind noise or also road/tire noise? Have anyone drive the x3 lci with and without the the acoustic glass and were you able to tell the difference? |
05-01-2023, 03:59 PM | #4 |
933
Rep 1,217
Drives: 2022 BMW X5 45e M-Sport
05-01-2023, 04:17 PM | #5 | |
2775
Rep 4,350
05-01-2023, 04:51 PM | #7 |
992
Rep 668
Drives: 2023 X3 xDrive 30i
Not sure about LCI acoustic glass, but I drove a US spec pre-LCI X3 M40i with acoustic glass for 1000 miles and it had no wind noise whatsoever. It felt like I was wearing a noise-canceling headphone. The model year is irrelevant for this because pre-LCI and LCI acoustic glasses share the same part number.
I also had a chance to drive 4 brand-new LCI X3 30i with regular glasses, and they all have different levels of wind noise but they definitely have more wind noise than the pre-LCI X3 M40i. I suspect the higher level of window noise is because BMW uses the same front window seal regardless of which front window you have but the acoustic glass is thicker than the non-acoustic glass. |
05-01-2023, 05:23 PM | #8 |
Snr Field Engineer 👮🏾*♂️
215
Rep 257
I have got acoustic glass on my pre-LCI and it keeps the cabin very quiet. In my other car I have to turn my head halfway to speak to, sorry, I meant shout at the rear seat passengers above the road noise. In Eco Pro mode the car is as quiet as an S-Class Merc (excuse me for the blasphemy, mentioning a rival brand), In my X4, I can whisper and rear seat passengers can hear me, maybe it’s the in-cabin microphone helping too.
Now for folks like me who are now used to this, there are some phrases I struggle to understand on this forum, namely: experiencing wind noise from the mirrors at high speeds, oiling the rubber seals on doors and windows to keep outside noise away. I guess the acoustic glass works wonders after all, it should be offered worldwide not just in Europe, so OP get it optioned to avoid regrets later.
Current - 2020 G02 X4 M40i, B58 engine, Alpine White.
Current - 2016 Toyota Rav4 D-4D, with BMW 2WW Engine, Blue crush metallic. |
05-01-2023, 05:44 PM | #11 | |
523
Rep 1,177
To you, OP, I haven't test driven one without, but with acoustic glass option, it's really quiet inside.
Iirc, it's based on option popularity. Most of us on the forums, we are a very minor portion of typical X3 buyers. It'd be great if there were stats on what options get taken, but usually, even for just a few hundred that's worth it, options often get left out (think adaptive suspension, acoustic glass, etc) that most normal people wouldn't even notice being gone. You add in a couple options and prices sometimes go up a lot, so dealers (when not doing custom options) opt to order options that have the most obvious impact and leave out ones that won't. As a result, BMW thinks it's unpopular option and discontinues it from build sheet. At least, this is what the salesperson I worked with back in San Francisco told me years ago when I was shopping for my F30.
2020 X3 M40i
2015 328i - Sold @ 104,000 miles |
05-01-2023, 05:59 PM | #12 | ||
590
Rep 411
Safety glass is constructed with a plastic laminate in-between two sheets of glass - the primary purpose being to increase safety for occupants by minimizing potential of dangerous shards of glass from detaching and injuring folks. They don't use tempered glass for windshields/screens - you don't want a freeway rock impact causing your entire front glass to essentially explode into hundreds of bits of glass. Even assuming you had a plastic laminate between two sheets of tempered glass, the rock could/would cause the entire windshield/screen to shatter and eliminate any viable forward visibility assuming it were largely held in place by the laminate. All of this is said with zero knowledge of Euro regs/practices, so YMMV there! Cheers~
Current:
2023 X3 M40i / Dark Graphite Metallic + Tacora Red 2014 Ram Limited / White + Black Leather 2009 335i x-Drive / Jet Black + Saddle Brown Dakota |
HuskerNSC119.50 |
05-01-2023, 06:16 PM | #13 |
391
Rep 1,283
So how can you tell from looking if you have the acoustic glass or just a laminated glass? Isn’t there some code #etched into the glass to show you indeed have acoustic glass?
05-01-2023, 06:17 PM | #14 |
523
Rep 1,177
If you lower the window, with acoustic glass you'll see a film layer in the middle.
2020 X3 M40i
05-01-2023, 06:19 PM | #15 | |
590
Rep 411
Visually, you can inspect the top / side edge of the glass panel and see if there is a laminate layer present. There's probably a BMW symbol etched on the glass, but visual inspection should be easy / straightforward. Cheers~
Current:
05-02-2023, 04:43 AM | #16 |
417
Rep 852
Some things just don't make sense. I have never understood why cars produced side-by-side on the same production line have different colour options for different countries.
05-02-2023, 09:17 AM | #17 |
451
Rep 544
So if I understand this correct:
1 - Front windshield - all markets get the same laminated / acoustic glass 2 - Front side windows - US does NOT get acoustic glass but Europe/other markets do |
05-02-2023, 09:18 AM | #18 |
2775
Rep 4,350
Yup, that’s about it. Although it’s a byproduct of safety for the windscreen.
05-02-2023, 09:19 AM | #19 | |
523
Rep 1,177
2020 X3 M40i
05-02-2023, 09:21 AM | #20 |
2775
Rep 4,350
05-02-2023, 09:22 AM | #21 |
523
Rep 1,177
Dang. That sucks even more than the diminished HK imo. It was like 300 bucks for a much quieter cabin.
2020 X3 M40i
05-02-2023, 09:23 AM | #22 |
451
Rep 544
As far as I know, not an option from BMW in the US. However, if your side glass is broken/damaged you can replace it with the acoustic type. If you don't mind the expense you can also replace it anytime. I always worry about technicians taking parts of the car apart for things like this. I am worried that I am going to get annoying rattles afterwards.
