raise rear h&r springs!!!!!!!! 1/2 a inch??
01-16-2009, 08:42 AM | #1 |
Rep 50
Hello Guys, is their a way to raise the rear maybe 1/2 a inch on H&R sport spring. I find that the rear looks to low, like sitting down to much... is their spacers, or other things that can be done, coilover is not a option!
thanks -------------------------------------------------------------- e90 330xi 2006, spyn ZX 19'', H&R sport springs, Parrot, rear fog, tint window. |
01-16-2009, 09:17 AM | #2 | |
Sensei
52
Rep 1,054
Put your OEM springs back on in the rear lol... But its not a good idea when the spring rates will be different from front to rear... So you might have to live with it
01-16-2009, 09:38 AM | #3 |
3071
Rep 4,393
Drives: 2022 F97 X3M Comp LCI
Uh... for adjustability coilovers are your only option.
BMW MY22 F97 X3MC LCI - CURRENT BUILD THREAD| Instagram: @danniexi
BMW MY16 F80 M3 - GONE BMW MY08 E92 335XI - GONE BMW MY06 E46 325XI - GONE |
01-16-2009, 10:48 AM | #4 | |
Wang D.D.S.
185
Rep 7,057
The height for spring drop is not changeable unless you get adjustable shocks. If you want to, try Eiback Pro-kit. That drop is more subtle.
02-04-2009, 11:59 PM | #5 | |
109
Rep 1,801
02-06-2009, 08:21 PM | #6 |
Get a grip. Get Xdrive.
14
Rep 529
Drives: 330xi
For the OP this is the very reason I got rid of my H&R springs. I have KWV3 now and no more rear sag. There are worth every penny as the ride is much better; the springs are match with the dampers. If I knew what I knew now I would have bought the KW in the first place.
2006 330xi current
02-06-2009, 08:38 PM | #7 |
the.tsukinousagi
118
Rep 1,538
Drives: 2015 F82 M4
I had the same problem. only way is to get coilovers.
I personally got H&R Coilovers |
02-06-2009, 09:56 PM | #9 |
245
Rep 4,494
eibach springs will have a more subtle drop, closer to stock than the H&R's
02-06-2009, 10:05 PM | #10 |
the.tsukinousagi
118
Rep 1,538
Drives: 2015 F82 M4
the front will always look higher with just springs.
FYI |
02-06-2009, 10:11 PM | #12 |
241
Rep 1,857
What if you kept the rear springs stock and swapped out the front with the eibach springs? I bet that would make the front and rear look even.
02-06-2009, 10:45 PM | #13 |
245
Rep 4,494
It probably would make the front and rear look even, but as someone mentioned earlier, I don't know if it's a good idea having different spring rates in the front and rear.
02-06-2009, 10:54 PM | #14 | |
Rep 50
If someone try`s it, please send some pics. <<< in the summer I have h&r springs and winter I have stock springs.>>> |
02-07-2009, 01:02 AM | #15 |
241
Rep 1,857
02-07-2009, 04:42 AM | #16 |
the.tsukinousagi
118
Rep 1,538
Drives: 2015 F82 M4
REALLY bad idea.
they H&R have a MUCH higher spring rate, so if you had a stiff and fast rebounding front springs, and the rear were stock, you are going to get a weird bouncy effect everytime you hit a bump. It totally defeats the purpose of you getting springs if you are only running fronts... your handling will be really messed up. don't do it, I had H&R Sport springs before i got the H&R coilovers, the stock shocks take a beating and will last anywhere from 20-50Km. So if you left the rear stock. your going to have to replace the front suspension way sooner. Maybe even before you will get annoyed of the rough and bouncy ride and want to spend the extra money to get coilovers. personal opinion. |
02-07-2009, 12:58 PM | #18 |
241
Rep 1,857
04-02-2009, 11:55 AM | #20 |
///M Specialist South Shore BMW
770
Rep 7,108
This is the one thing I dont like about my H&R's. rear is too low. I might get an FK coilover system soon.
2021 M5 COMPETITION LCI Brands Hatch Gray on SIlverstone, carbon roof, comp wheels, Mperf splitter, carbon pro spoiler, carbon diffuser , carbon paddles, executive pkg. Dinan HAS, RaceChip, dinan spacers, FC stud kit, etc
04-03-2009, 11:32 AM | #21 |
78
Rep 164
Eibach's are on Ebay. $252 shipped.
I'm installing them now. Eibach's on the front with zsp's on the rear. Eibach's and zsp's have almost the same spring rate. I'll post pics when done. |
