Quality aftermarket oil pan (N55?)
02-18-2023, 08:29 PM | #1 |
1324
Rep 1,178
Hi all,
Long story short, the dealer which sold my 335i to me used an oversized drain plug + impact driver, and in the process ruined my oil pan. They’re working with me on payment / compensation, but it’s a hard enough battle as it is to get them to comp me the 3K quoted by BMW to replace the oil pan. The lowest price I’ve seen the OE BMW N55 oil pan (11-13-7-570-400) is $780 through BMW South Atlanta. For most parts I’m used to seeing OEM suppliers, but I haven’t seen anything beyond the ECS Tuning (Bremmen Auto parts) branded one, which as I understand is made in China (something I’d rather stay away from). FYI the last 7 of my VIN is E825667. Just wanted to see if there was a reputable aftermarket alternative available. Totally open to performance upgrades as well, as long as it’s not more expensive than the OE BMW part. As an aside, I’m thinking about doing rod bearings too, since the vast majority of labor will already be done, although my car is a very late production (10/2011)… Thanks as always!! |
02-18-2023, 08:45 PM | #4 |
1324
Rep 1,178
02-18-2023, 08:47 PM | #5 |
1324
Rep 1,178
02-18-2023, 08:58 PM | #7 |
1324
Rep 1,178
02-18-2023, 09:17 PM | #8 | |
1691
Rep 3,652
Here's one for $160! I'm sure if they're paying for it they wouldn't mind going used. Ship to your house first to confirm it's a good one, but stripping threads isn't super common so I wouldn't worry too much. New from rockauto for $220 also sounds great. Being N55, I would HIGHLY recommend doing your rod bearings while you're in there. It's worth the $500 extra or so you'd be out for it, esp if the oil pan job is free ish. |
02-18-2023, 09:52 PM | #9 | |
1324
Rep 1,178
Good point on the threads, plus if they are stripped I can always return the eBay ones. Mine does have the updated bearings, being a 10/2011 build (or am I mistaken?), but you’re right about the preventative maintenance. |
02-18-2023, 09:58 PM | #10 |
1691
Rep 3,652
From what I've seen, all of the E chassis N55's spin bearings extremely often so if it were mine I would still do them. That being said, sounds like you're up to date on the issue if you know your build date and when they switched bearing material so you can make a good informed decision either way. Good luck with the oil pan venture!
02-18-2023, 11:52 PM | #11 |
1085
Rep 1,677
Couldn't the shop just put in a repair plug while keeping the same M12 bolt?
The Spectra one on Rockauto carries a 3-year warranty. Should be ok, fingers crossed. Otherwise there should be a lot of N55 oil pans out there from engines with seized bearings. |
02-19-2023, 04:18 PM | #12 | |
1324
Rep 1,178
I asked about that, but apparently there isn’t much metal left. Plus the dealer is willing to pay for it to be replaced, so I’d rather go that route to be safe. |
