11-22-2022, 10:21 AM | #1 |
1916
Rep 2,135
1 year/10,000 miles oil change required?
I think I read a post about this somewhere but couldn't find the definitive answer.
So I took delivery of my car Nov. 18, '21 I get that it's been exactly 1 year since delivery, but I've had my break-in service done in June 18, '22 It's been 5 months, 1,000 miles since the service and the car is prompting for the annual oil change. Is this service necessary? If not, I'm curious why BMW didn't reset the oil change interval/reminder. I was planning on doing my own oil changes anyway... just wondering if I should consider doing one earlier than 5k miles. |
11-22-2022, 03:58 PM | #2 | |
13474
Rep 6,962
Drives: 2022 DG/BLk xDrive M4C Wk 34
If you changed it 6 months ago, and just let it sit in the garage, with no miles on it, after the oil change, you could come back later, and it could be down to 80 or 90%.
2022 DravitGrau /Black Full Merino M4 Competition M xDrive / Production Week 34/ Delivered 10/19/21/ IG: dravit_m4_comp
YT: G Dubyou |
11-23-2022, 09:11 AM | #4 |
2567
Rep 1,929
That's just wasting oil.
11-23-2022, 09:22 AM | #5 |
101
Rep 140
There's no reason to change the oil every 2k miles, but I would recommend it at least once yearly.
Here is a good excerpt sent to us by Blackstone when finalizing oil service interval recommendations for our shop a few years ago. "As the engine operates, acidic by-products from the combustion process get past the piston rings and into the oil. The acids combine with moisture (every gallon of gasoline burnt produces up to a 1/2 gallon of moisture) which can dissolve bearing surfaces. Modern motor oils contain additives to combat the acid buildup in the oil. As the oil becomes contaminated and turns acidic, the additives get used up. Preventing acid buildup is a very big reason for changing motor oil regularly. Short trip driving is the worst kind of driving for this problem as moisture is not boiled off during driving cycles." I've also been told by a BMW Engineer that acidic oil/moisture plays a large part in the degradation of gaskets and contribute to oil leaks. |
11-23-2022, 03:07 PM | #6 | |
220
Rep 401
reNT265.50 |
11-23-2022, 03:28 PM | #7 |
2567
Rep 1,929
Do you track your car and your oil analysis finds shavings in the oil?
12-20-2022, 06:43 AM | #9 |
330
Rep 984
Depends on how you drive the car. If you track it regularly, I would lean towards 5K miles oil changes. If you tune it and track it, definitely 5K miles oil changes. Just tuning it, would be around 7.5k miles. If left as stock, general rule of thumb would be 7.5-10K miles.
04-30-2023, 08:06 PM | #10 |
2072
Rep 1,159
So does this confirm the 1yr or 10k mileage service is from the date of delivery not the date of the break in service? I guess there are some low mileage M cars that may not even do a full 1,200 miles in a year… wonder how that is treated at the annual maintenance… would they do the rear diff fluid if at say only 600 miles.
05-01-2023, 06:56 AM | #11 | ||
Occasionally frequent poster
3000
Rep 2,744
However, just sitting in the engine, oil does get contaminated by condensation, especially if those 1K miles were a lot of short trips that never really got the oil hot enough to boil off the water. So I generally follow the guidelines of XX miles or 1 year, whichever comes first. Quote:
Current inventory:
F22 & G05 Cadillac CT5-V Blackwing w/3 pedals Past: E24,E28(3),E34,E36,E37,E38(2),E39(4),E46,E89,E92 (obviously),F01,F06,F10,F30,F87,G12,G30(2),G82(2) |
05-02-2023, 03:57 AM | #12 |
234
Rep 320
In Europe we have approx 18k-20k miles between oil services and no annual tick. I do however, plan to do a change at 10k, at my cost, and not have them reset the interval so I still get the scheduled change under the service plan
