Coding after power memory seat retrofit??
09-20-2022, 02:56 PM | #1 |
Rep 2
Hello all,
I've got E90 LCI 2011 and I've retrofitted new seats into my car, but Ive got an issue now. PROBLEM: After the retrofit, most of the time my mirrors just adjust themselves (they go all the way in and down) on unlock, turning on ignition, etc.. so I have to almost everytime adjust them when entering the car. This started happening only after I've retroffited my seats, didn't happend before at all. Seats were properly retroffited (grounds added to the ground blocks, new power wires from seats to the correct spot in fusebox with correct fuse amperage, can bus wire was ran from CIC idrive controller), all features on seats themselves work (power moving, memory, lumbar, side bolsters, heating) BEFORE RETROFIT: I've had normal/non-sport manual seats with only heating (no lumbar or memory) and power folding mirrors with passenger mirror tilt on reverse AFTER RETROFIT: Now I have power memory sport heated seats with lumbar, side bolster adjustment (mirrors werent touched, they are as stated above) My question is: Do I need to code modules and add VO code to the car to prevent my mirrors from going all the way in and down each time? If so, is there any guide to follow? Many thanks! |
09-30-2022, 06:15 PM | #2 |
eBay Special
3102
Rep 3,038
Drives: E90 330xi
Have you tried setting the memory on the seat yet?
Common sense is a flower that does not bloom in everyone's garden
