ET27 19X10 on 275 tire?
12-19-2008, 01:48 AM | #1 |
91
Rep 776
How hard is this going to be to fit a e92 335i
E92 M3 Clubsport
JRZ | TE37SL | AR1| Stoptech BBK (ST60/40) | Recaro SPG XL + Schroth 6 point | Raven Roll Cage | | Alex Alpine Tune | Turner Test Pipes | AFE Carbon Intake | Bimmerworld Solid Bushings and more... |
12-19-2008, 11:44 AM | #4 |
91
Rep 776
not yet
I'm on stock sport suspensions
E92 M3 Clubsport
12-19-2008, 12:07 PM | #5 |
654
Rep 10,587
plan on lowering it? sounds like yes.
that will be very tight, but heavy rolling and camber should do it.
12-19-2008, 12:19 PM | #6 |
Modder Raider
753
Rep 8,633
Drives: M3
There's no way.
You are guaranteed to rub.
e36 M3 Coupe, e36 325i Sedan
e90 335i--SOLD Best 60-130-------------9.15 Seconds------------------WWW.MR5RACING.COM |
12-21-2008, 02:58 PM | #8 |
83
Rep 1,861
Drives: 2008 E92 335i
First of all I don't see it happening without fender rolling and alot of negative camber. Secondly, even if it does work without rubbing I think it will look bad cause it'll stick out to far. Here's a pic of mine with the rim as flush with the fender as it will get. I am running 275/30/19 on a 19x10 wheel et 35....thats right....only 35, now you do the math n picture what et27 will look like. I might have been able to go with et30, but I probably will have issues when I lower it, so I think my set up is perfect. MY $0.02
12-21-2008, 03:37 PM | #9 |
Perf BMW mag issue 147, 159
414
Rep 6,803
i like poke... you'd probably have to run a 265 or 255 though.
'13 Estoril Blue 335i M-sport
*Don't PM me!* Message me here- http://www.facebook.com/ProjectEstoril |
12-21-2008, 04:34 PM | #10 |
83
Rep 1,861
12-21-2008, 08:42 PM | #12 |
152
Rep 2,461
wow alot of misinformation here
I ran 19x10 with a +25 on a fk452 tire (265) and I only rubbed on dips/bumps but would be fine with a fender roll, no neg camber and Im dropped on HR sports.... poke and stretch tires ftw |
12-21-2008, 08:50 PM | #13 |
91
Rep 776
i guess the only way is to try them on thanks guys
E92 M3 Clubsport
12-22-2008, 10:28 AM | #17 |
The 3 Day Diet!
19
Rep 630
Drives: Space Gray e92, 88 911 Cab
I have 33et 19x10 M6 reps with 275 Toyo T1-R's. HR Sport springs. It is perfect. No fender rolling or adjustments made.
2007 BMW 335i coupe, Step w/ Procede, Aero Lip, H&R Sport Springs, M6 reps, Toyo T1R 235/275's
1988 Porsche 911 Cab, 47k, SW chip, cat pipe, M&K exhaust. |
12-22-2008, 10:37 AM | #18 |
98
Rep 3,618
But isn't an xi on HR springs quite a bit higher than a RWD E92 on coilovers? I mean xi cars sit higher to begin with, lowering springs drop them about 1 1/4" overall. Then we have coilovers that have the potential if adjusted as such to lower the rear on either the AWD or RWD E92 by up to 2".
2016 Mercedes-AMG CLA45
2013 Mercedes-Benz B250 - Gone 2010 Mercedes-Benz C350 4Matic - Gone 2006 BMW 330xi - Gone 2001 Infiniti QX4 - Gone |
12-22-2008, 10:28 PM | #19 |
100
Rep 2,528
Drives: 95 Avus M3 and 07 E90 Fam Car!
12-24-2008, 09:51 PM | #20 |
115
Rep 1,439
run a toyo 265 tire, the sidewalls tend to be more rounded than other tier makers out there, allowing you to go for a more agressive setup.
drop it, roll the fenders and you should be fine |
12-26-2008, 03:41 AM | #21 |
198
Rep 4,647
You will need to roll fender and will need to run tires that have roundy sidewall. I've seen people running ET23 with 265s~275s so i know it can be done but it will require more work than just "taking it out and putting it on"... IMO, not really worth it. Do minor fender roll and run 265 and you will be golden...
http://www.e90post.com/forums/showthread.php?t=132144 |
