08-05-2022, 09:26 AM | #1 |
85
Rep 126
BMW says I need a friction disk
My car has been at BMW for the past few days for a clicking noise in the front suspension. I hear this noise when my wheels are fully turned backing out the driveway at low speeds.
The service advisor calls me today and he says he believes my car needs a friction disk to avoid this sound. The shop foreman now has the car, and I will get another update tomorrow. Has anybody else had this issue? Car is completely stock. |
08-05-2022, 10:38 AM | #2 |
885
Rep 897
Mine does it too, it's common. Nothing bad something to do with hub rubbing. I just live with it.
kingmatt9284.50 M3X_TB2284.00 |
08-05-2022, 10:55 AM | #3 |
207
Rep 253
Drives: BMW M3 Comp Xdrive
kingmatt9284.50 Limegrntaln13472.00 |
08-05-2022, 12:48 PM | #4 | |
85
Rep 126
Limegrntaln13472.00 M4Tejas788.00 |
08-05-2022, 01:18 PM | #5 | ||
207
Rep 253
Please keep us in updated. We also have a 2021 x5 M50 but never heard any noise. |
08-05-2022, 03:18 PM | #6 | |||
85
Rep 126
M4Tejas788.00 |
08-05-2022, 03:35 PM | #7 |
13472
Rep 6,962
Drives: 2022 DG/BLk xDrive M4C Wk 34
Just about every suspension lowering thread, mentions this clicking. I had it stock, I just had the M Performance HAS installed, the other day, and now the clicking is a little more prevalent. Hopefully they figure it out.
2022 DravitGrau /Black Full Merino M4 Competition M xDrive / Production Week 34/ Delivered 10/19/21/ IG: dravit_m4_comp
YT: G Dubyou |
M4Tejas788.00 |
08-05-2022, 05:20 PM | #8 |
Riding the knock sensor
2371
Rep 1,591
Drives: 21 X5MC | 23 M4CSL
Isn't a friction disc a brake rotor? I'm not familiar with any suspension component referred to as a friction disc. I don't know everything but enough to call this out as odd.
08-06-2022, 11:38 AM | #10 |
You got my money?
3156
Rep 4,646
Drives: Ice Cream Truck
Interesting. So you guys hear this?
https://www.youtube.com/shorts/_hiAbt20_FM And you are not lowered???
2022 G80 M3 Competition X / 2020 Range Rover Sport P525 / 2023 Ford Raptor
M4Tejas788.00 |
08-06-2022, 11:58 AM | #11 |
885
Rep 897
No its not static, you need to be moving. I had it on my M240i as well. BMW has known about it for 8-10 years at least.
There was an SIB for that and later was updated to include a "friction disk" that goes between the brake disk and hub. It's literally a very very thing ring of something that acts as a spacer of sorts. EDIT : Bingo - I found it https://www.turnermotorsport.com/p-2...n-washer-ring/ Sometimes loosening and then re-torquing the wheel bolts to spec helps for a bit. I've learned to just ignore it it doesnt hurt anything. SI B34 08 14: Ticking Noise from Front Axle When Cornering SITUATION The customer may complain of a ticking noise from the front axle when cornering, maneuvering, parking or pulling away from a parking space. The noise can be heard as a light metallic ticking from the front outer cornering wheel. CAUSE Movement between the brake disc and wheel bearing hub. CORRECTION Remove and clean the front axle brake discs. Sand the hub surface on the brake disc to the wheel bearing hub using 80-grit sandpaper. Sand the surface in a radial motion (inside to outside around the surface. Clean the wheel bearing hub surface. Important!! Do not sand the hub surface. Do not apply any type of lubricant to the components surface (wheel bearing or brake disc). Reinstall the front axle brake discs. |
08-08-2022, 12:40 PM | #12 |
223
Rep 396
I had clicking on my F80 and F10 M5 - both lowered. Took it in w/ the SIB, they performed the cleaning and installed the disk. On the F80, which was worse, it took about 80% of the clicking noise away. 100% gone on the F10.
I anticipate having to do it on the G80 I order, too.
current: 23 g20 m340ix
previous: 2016 f10 m5 /// 2017 f80 m3 zcp /// 2004 e46 m3 zcp /// 2010 e90 335i msport |
08-08-2022, 01:11 PM | #13 |
85
Rep 126
According to my service advisor I'm now waiting for BMW to approve putting on the disk. In the meantime I picked the car up. I'm not sure why bmw would deny it but he told me to give him about a week to hear back from BMW.
08-08-2022, 01:18 PM | #14 | |
BimmerPost Supporting Vendor
8215
Rep 18,823
Drives: BMW
https://static.nhtsa.gov/odi/tsbs/20...47541-9999.pdf
Tom G. | european auto source (eas)
email: tom@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x22 GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM |
08-08-2022, 03:43 PM | #15 |
2566
Rep 1,929
That's crazy, the clamping force on the hub/rotor is like 15000lbs with 5 lug nuts, and its rotating?
08-08-2022, 04:11 PM | #16 | |
1827
Rep 830
I had this done to my M2 back then…I have the clicking noise on my G82 too and already asked my dealer about anything similar for it. He said there is no official instructions for the G8X yet. |
08-08-2022, 07:21 PM | #17 |
13472
Rep 6,962
I was at an event, yesterday, and noticed an F90 M5 doing this "clicking" with the M Performance suspension. I also had the sound on my car, before the suspension.
YT: G Dubyou |
08-09-2022, 09:20 AM | #18 |
You got my money?
3156
Rep 4,646
Did you have wheel spacers before lowering when you heard it?
08-09-2022, 12:18 PM | #19 |
13472
Rep 6,962
Both. I heard it before I put the spacers, on. The spacers changed nothing. Then installing the springs, it is still there.
YT: G Dubyou |
08-21-2022, 03:00 AM | #21 |
476
Rep 172
I'm hearing this clicking as well. Only at very low speeds, after fully stopping/braking and I nudge forward with the wheels fully turned there is 1 click. Usually can repeat it but sometimes doesn't happen. So what's the verdict? Take it in? It's kinda annoying... Clicking in $90k car 🤔
2022 M4 xDrive BSM, Fiona Red.
Instagram: @Carsandsnaps |
08-21-2022, 10:07 AM | #22 | |
You got my money?
3156
Rep 4,646
