Tire pressure low for weeks
12-17-2008, 11:30 AM | #1 |
Rep 7
Sorry if this has been posted elsewhere...
About 3 weeks ago I got a message from the Tire Monitoring System saying that one of my back tires (RFT) was low on air. I was unable to remedy the situation at the time due to having to fly out of town. Three weeks later, the message is still there but it doesn't seem as though the tire is flat or losing air. My question is that if there was indeed a leak, wouldn't the tire be completely, or at least noticeably flat by now (three weeks later)? |
12-17-2008, 11:34 AM | #2 |
3187
Rep 10,509
it is a run flat tire. it is designed to hold up the weight of the car for driving without any air, so a bit of time with low air is not going to deform it
however, you are causing a lot of premature tread wear on an expensive tire, so definitely inflate it to the proper pressure asap |
12-17-2008, 11:43 AM | #3 | |
1469
Rep 3,553
runflats will not look low on air, which is why there's a tire pressure monitoring system installed. driving on it with very low pressure pretty much guarantees that you wont be able to patch it and will need to buy a new tire.
Present: 2023 G07 40i ZDH/ZDU/ZMP/ZMQ/2NH/ZPK/ZPP/ZRC/300/3AC
Past: 2013 335i 6MT ZMM/ZDH/ZTP/3AG/494/508 Past: 2016 F34 335i xDrive ZCW/ZDA/ZDH/ZTP/ZMP/2V5/5DL Past: 2019 G01 M40i ZDA/2VF/ZPP/ZPX/688/3AC |
12-17-2008, 11:44 AM | #4 |
Rep 7
If I were to measure the tire pressure I should see a difference in that tire's pressure when compared to the other three wheels, correct?
Should I then inflate it to the correct pressure, reset the Monitoring System, then see if it raises the warning again? |
12-17-2008, 11:52 AM | #5 |
PuffPuffPass
52
Rep 1,096
Cold weather is pretty much it...Check the PSI and make sure they are at 32/35 they are probably less than that.
When the weather turned REAL cold 30F and under i had the tire pressure say its low and after i filled it up it was good to go. And also if you have a flat tire in run flats YOU WILL NOTICE IT.. The car will merge to one side like crazy and you can tell by the tires..So pretty sure its not a flat and just cold weather. |
12-17-2008, 12:05 PM | #6 | |
1469
Rep 3,553
i had a rear runflat at 4psi and i could not easily tell it was flat. the car handled normally. i found the tire was flat by checking each tire.
12-17-2008, 12:18 PM | #7 | |
PuffPuffPass
52
Rep 1,096
Maybe it was because the nail was one of those HEAVY duty 2inch round 6 inch long nails but yea i felt it alot... |
12-17-2008, 12:27 PM | #8 |
Rep 7
Thanks for the input. I'll check the tire's pressure and see if it is indeed flat. How much should I spend on a pressure guage? I know they range from the cheap pocket tire gauges ($3) to the sophisticated electronic ones ($30+).
12-17-2008, 12:28 PM | #9 |
PuffPuffPass
52
Rep 1,096
$3 dollar ones does the same job IMHO and there isnt enough times to use it anyways..
Or just go to one of those Air filling machines that has one on it. |
12-17-2008, 01:46 PM | #10 | |
1469
Rep 3,553
get something like this: http://www.amazon.com/Accutire-MS-40...9543032&sr=8-2 and a cheap portable air compressor.
12-17-2008, 02:00 PM | #12 |
3187
Rep 10,509
You can definitely get a small air compressor that plugs into the car's 12V socket for around $9 (i got mine from Kragen's). Much more convenient than driving to a gas station
12-17-2008, 03:12 PM | #13 |
just another bmw douche bag
195
Rep 3,640
and also, there is a sticker on the driver's side door jamb that has some specs on it - including your car's recommended tire pressures. Just about all modern cars have this sticker, so it's easy to reference. And the owner's manual has tire pressures for different size wheels and tires, in case you have upgraded from stock.
