160k NO CBU, possible?
07-22-2022, 10:51 AM | #1 |
Rep 40
Hey all,
I'm just over 161k with no record of CBU or Walnut Blasting... car runs great, 6k Oil changes, Fuel Filter every 4th oil change. Ive owned the car since 43k and never had any CBU related codes, I've never had it cleaned and do not recall seeing it on the prior service history . Im seeing lower overall mpg on the OBC (23mpg) and I've got 4D16 (SCR efficiency) and 452A (DPF lifetime) codes. 452A does not cause MIL 4D16 trips MIL and returns within 500-700 mi of clearing. Question is: Do I clean CBU in hopes of improving combustion and clearing the efficiency code or do I need to bite the bullet and get a new DPF and SCR cat? Also interested in hearing DPF cleaning experiences, ive spoken to two cleaning outfits who say the BMW DPF has an additional OX CAT in the DPF that must be removed prior to cleaning and reinstalled (cut open and weld closed DPF) HELP, im only a few months away from my SMOG inspection ... I will not pass in the current state. Please refrain from telling me to delete the car, I am well aware of the pros and cons of these modifications I wish to remain compliant with CA SMOG laws at this time.
Current Fleet:02 M5 Carbon Black - 11 335d M-Sport Alpine White - 08 Cooper S Pepper White - 07 Range Rover Supercharged Java Black
The ones that got away:02 M3 Vert Jet Black - 04 A4 3.0 Quattro Brilliant Black - 77 Mercedes-Benz 300D Milan Brown Metallic - 02 Range Rover Java Black - 84 Mazda 626 Diesel Last edited by peteyypab; 07-22-2022 at 04:53 PM.. |
07-22-2022, 11:07 AM | #2 |
Rep 40
Additional Information:
The ones that got away:02 M3 Vert Jet Black - 04 A4 3.0 Quattro Brilliant Black - 77 Mercedes-Benz 300D Milan Brown Metallic - 02 Range Rover Java Black - 84 Mazda 626 Diesel Last edited by peteyypab; 07-22-2022 at 12:59 PM.. |
07-22-2022, 01:22 PM | #4 | |
Rep 40
In your experience could 4d16 be caused by CBU alone ? Could 4d16 be caused by a "spent" DPF/OX CAT? I gave the code clearing information to give you a picture of frequency, from my understanding 4d16 is tripped after 2 “inefficient” regens? - This metric has changed, was throwing it much more frequently until thermostat replacement. I’m aware there is a problem and just want to apply the correct fix without shooting the parts cannon aimlessly. Last edited by peteyypab; 07-22-2022 at 04:53 PM.. |
07-26-2022, 06:11 PM | #5 | |
277
Rep 1,576
07-27-2022, 05:14 AM | #6 |
Rep 40
Besides CBU, everything has been over maintained (early oil changes, filters, ALL vacuum lines,etc) just never had any cbu related or injector codes
Interestingly enough I hit the low def level (999 no start) and refilled with 2.5 gallons supertech DEF in the passive tank, all monitors are ready and it’s been ~600 miles Here’s to hoping it was just poor quality Peak DEF |
08-08-2022, 11:22 PM | #7 |
26
Rep 53
How mechanical are you? You can pop the intake manifold off and inspect the ports. Also, where are you located/what kind of climate are you in? CBU is going to be exaggerated in cold climates.
If you're not getting enough fresh air, it can cause regen issues, but the ECM will also see this with MAF readings, and you should see faults there. |
08-09-2022, 07:48 PM | #9 |
43
Rep 237
The dpf meter can be reset. It expires around 160k miles. Its a hard countdown clock. The foxwell scan tool can reset it. As long as the dpf isn't clogged it should be good to go for a while.
I've had the 4D16 code a couple of times. I have pulled the rear nox sensor off and spayed it with brake clean to remove the soot build up. Ive cleaned it at 130k and 200k but I've just replaced the nox sensor after the 3rd time. The brake clean didn't work well so I replaced it. Make sure your scr temp is at the correct temp. If not then it has to be replaced. When you erase error codes, it resets the I/M monitors and the SES light comes back after about 500 miles or after the car has run a full tank of fuel because the scr and dpf monitors are the last to reset. So the SES light stays off until those monitors reset and if the code is active the light will come on. If the errors are not active but in history the SES light will turn off after a 3 or 4 drive cycles. In my state to pass vehicle inspection, only 2 monitors can be incomplete, all others must be ready. Last edited by 335D Alpha Pappa; 08-09-2022 at 07:55 PM.. |
POBEP367.00 |
04-12-2023, 05:06 PM | #10 |
Rep 40
Update time:
its been a few months, 178K now and counting... no changes made BUT:
Im thinking I either have a flaky/wonky NOX sensor or something is affecting my DEnoX process or my SCR is just not meeting the threshold for 4d16 code set criteria. I have concluded my SCR/DPF is working at least to some degree... When I clear codes I can get through several tanks of fuel (including a regen) and get all I/M readiness monitors passed with no pending codes. continue driving anywhere from 800-1500 miles and BAM 4d16. Passed Smog but would like to get this cleared up and maybe get a few MPG back in the process??
The ones that got away:02 M3 Vert Jet Black - 04 A4 3.0 Quattro Brilliant Black - 77 Mercedes-Benz 300D Milan Brown Metallic - 02 Range Rover Java Black - 84 Mazda 626 Diesel |
04-13-2023, 09:11 AM | #11 |
29
Rep 92
Drives: 2011 BMW 335D
I don't think that regular preventive maintenance will prevent the need for a carbon cleaning...but an EGR block off/delete will.
04-13-2023, 04:32 PM | #13 |
Rep 40
Both NOX Sensors replaced by dealer in 2017 at 97k, thus my current sensors are 6 years old with 80k on em.
Could it be that the NOX Sensors are just lazy but not throwing a code?? I would like to think you would get plausibilty or out of range codes with a failing sensor and not just the 4d16 Anyone have some known good NOX sensors for some testing?
04-14-2023, 05:46 PM | #15 | |
277
Rep 1,576
04-14-2023, 05:49 PM | #16 | |
277
Rep 1,576
04-20-2023, 12:32 PM | #18 |
29
Rep 92
I am no expert, but it isn't very difficult to pull your intake manifold off to look.
If you see anything that looks like this picture, I can't imagine how any type of driving will clean this mess up. |
04-20-2023, 06:41 PM | #19 |
Rep 105
If its a highway vehicle, with no to very little idle city traffic, then I can see no carbon build up. I have 108K on mine and never seen what other posters have shared images of their cbu. I drive mostly highway and the ports are pretty clean!!!!
