07-10-2022, 05:22 PM | #1 |
451
Rep 675
I have a 2018 M550 with about 60,000 miles.
I bought the car certified preowned about a year ago and I've done a lot of Freeway driving and have noticed a significant number of rock chips along the lower portion of the hood. When I bought the car I did not do any kind of paint protection now I'm thinking I should have …. At this point I'm thinking about having some kind of professional correction done but I'm wondering if it's even worth it is it too late ?? I'm planning to keep the car at least three more years before I sell or trade it in on something newer I am wondering if I could get the rock chips repaired and then have paint correction and ceramic film applied or if I would need to have the front end actually repainted. Most of the chips are very small like little pinpricks there are a handful that are more significant in size if I were to do it myself I'm sure I would screw it up and it would take forever I figure a professional detail or paint correction place might have the ability to fix it before they apply a ceramic coating or if that would just look like crap and I'd be better off to spend a little bit of money and have the front portion repainted? My car is med blue - my car looks identical to the blue car that is on the forums main page It doesn't look bad it's just at once I wash it and wax it up you can tell the front end doesn't look as pristine is the rest of the car I'm sure most other people don't notice it but I notice it and I'm trying to figure out before I start calling paint shops what kind of actual budget I should consider for all of us to be done. If it's gonna be crazy expensive I'll just spend the money for detail work and figure it'll look good enough but if I could do it for not crazy money I'd consider correcting it now so it looks sweet the rest of my ownership Thx
Sean
2016 X5 sDrive 35i 2018 M550i |
07-12-2022, 08:36 AM | #2 | |
7338
Rep 6,749
Drives: '18 M550i|'21 X5|'03 540i
Garage List 2013 VW Tiguan [0.00]
2015 Infiniti QX60 [0.00] 2021 BMW X5 [0.00] 2003 BMW 540i [0.00] 2018 BMW M550 [10.00] |
You can have a professional fill in those chips and then have it corrected, ceramic'd and PPF's. However, I highly recommend you give Dr. Colorchip a try. It is literally dummy proof. You can't screw it up. It is definitely work a shot. This is what a lot of the pro's use. After you try it, then see if you are happy with the results and if so, then have it corrected, then do Dr. Colorchip again, then ceramic and then PPF. Watch some video's on Dr. Colorchip.
2018 M550ix|Carbon Black|Dinan Modifications|2003 540i|Jet Black|M-Sport|2021 X5 Mineral White
Prior BMW's: 1987 325e|1993 740i|1998 740il|2001 530i|2002 745li|2007 750li|2006 750li|2001 530i|2012 535xi| |
rswitch40.00 |
07-14-2022, 02:19 PM | #3 | ||
40
Rep 168
rswitch ..
07-14-2022, 02:50 PM | #4 |
7338
Rep 6,749
I wish I knew about Dr. Colorchip sooner. It's super easy to use and as I said, dummy proof. No globs.
rswitch40.00 |
07-15-2022, 12:57 PM | #5 |
396
Rep 385
I had the same issue on bumper and hood. Used Dr Colorchip for the most part on the pin hole sized chips on the hood. Came out really good.
For larger chips on bumper I ordered paint from automotive touch up and the langda kit. Also did spot wet sanding and used rotary buffer with megs 105. Is it perfect, no. However it beat spending 1k or so on a bumper respray. Without PPF chips will continue to occur. A couple lessons learned. For a CPO car visual inspection is key most will already have chips. If found you can try to negotiate in a bumper respray. For new I would definitely invest in PPF at least the front of the car would be done as Joe suggested. |
07-15-2022, 01:20 PM | #6 | |
7338
Rep 6,749
07-31-2022, 05:37 PM | #7 | |
Retired Curmudgeon
2985
Rep 4,047
I went the hard route instead: Artist 3/0 brush, touch up paint, 2000 grit wet sand, rinse/repeat until every chip filled and leveled, Rupes 15 with coarse pad and coarse compound. 3 days later it was easy as pie to put the Avalon King ceramic coating on it.
'19 X3 M40 Carbon Black/Oyster, '23 Jeep Grand Cherokee L Summit, Past BMWs: '18 M550i, '18 330 GT, '16 X5 40e, '11 E90M3, '06 X5 4.4, '03 330i ZHP, '02 M3, '97 Z3 2.8, '95 M3 (2x), '94 530i (manual), '92 525i (manual), '88 M3, '87 325iS |
Mandingo93498.50 |
08-17-2022, 01:40 PM | #8 |
47
Rep 78
Keep in mind that Dr. Colorchip isn't really a paint chip repair. It's more of a paint chip disguise. It's very difficult using Dr. Colorchip to completely fill in a paint chip. It definitely makes the paint chips less noticeable (especially if your primer and color coat have a lot of contrast).
After initially using Dr. Colorchip as a "quick fix" I ended up coming back at a later date with actual touch up pain and sanding/buffing it down. |
admranger2984.50 |
08-17-2022, 01:48 PM | #9 | |
7338
Rep 6,749
09-30-2022, 10:36 PM | #10 |
253
Rep 295
Dr color chip for small chips, I find using factory touch up paint with Langka better for deep chips. Langka is a bit more work, but equally goof proof.
http://www.langka.com/ |
Joe-BMW337337.50 |
